1 - 8 of 8 Posts
· Registered
I am getting a set of used Volans for my 855. I am just wondering what tires people use, and what PSI you run? Any other input also would be great.
· Registered
Hey,
I run 215/45-17 Yokohama AVSi tires at about 38psi. Have same suspension setup as you; Bilsteins, ipd rear overload coils.
Slight rub at full steering lock, never happens during "normal" driving. No rub anywhere else with this setup.
I wouldn't bother with 205/45 tires, too fragile in the sidewall.
I'm about to drop my car with H&R Sport Springs, I'll post results here.
Good Luck!
Adam
'96 855R
Bilsteins, Supersprint, K&N, Bosch+4, E-code headlamps
· Registered
i used to run 32 psi on 205-45-17 pzero assym...result? 4 blown tires (albeit city paid for cost after claim). now i run at least 36...usually 38 on bridgstone s-02 pp. i would run anything above 36...too low and u'd have easy blow outs (although i doubt if i had run it over at higher psi it would've made any diff). 38~42 should be good.
· Registered
oh, and i have bilsteins hd and ipd springs on all four...i'm waiting to get fenders lipped (the 215-45-17 are slightly rubbing up front)...215-40-17 may not be thick enough (or have high enough load rating) for our wagons...
· Registered
Cool, thanks for the input. I should be getting the wheels on monday (tomorrow)
I will post pics after I get them put on.
1 - 8 of 8 Posts
