Hey all, I will soon pluck up the courage to do this. I have a quick question. When you are driving in D or S what happens when you change the gears with the paddles, does it temporarily shift into manual mode and then back again if you don't use the paddles again within a certain time?
For mine, when your in D and use the paddles it changes back to just regular D after a few seconds. When in S and you use the paddles it stays in paddles till you manually move the gear knob back to D
ok thanks, is your the retro fit?
No it’s not. It’s how it works from the factory
Ok well that I figured, I want to know what occurs in the pre MY14 models that have been retro fit with the paddles.
