1 - 20 of 39 Posts
Travelling to Sweden and may try to pick up a pair of euro headlights while there. Obvisouly this is in order to get the better high beam performance, but how does DRL work?<br>I would assume the DRL functionality is then performed by the low beams at all times?<br>Is this automatic or do you have to do any kind of software download to enable this functionality?<p>Also - can you use *any* S60/V70 Xenon light light housings? I understand I may loose the silver color surround and instead it's black, but it may be easier to find a set of used Xenons from any S60/V70 versus from an R. Seems like they were part of packages when the car was sold new. <p>Also - anyone happen to have the part number? Makes it easier to search the the parts over the phone?<p>Thanks!<p><BR><BR>
<i>Modified by FastWgn at 9:50 AM 7-29-2009</i>
Re: Question for people with Euro lights (FastWgn)
Mine were silver not black, you lose all DRL's...period.<p>The Euro light has no DRL function, if it goes to a country that requires DRLs then I believe Volvo installed the US style light on those cars
Re: Question for people with Euro lights (JRL)
Thanks for your reply. Yours were silver since you bought the "R" version, I woudl assume? <br>The normal S60/V70 was also sold with Bi-Xenons in Europe, but with the black surrounds.<p>So no DRL at all? So in Sweden (where DRL has been the law since many, many years) they used the US spec headlights? Interesting...<br>I would have thought they just ran the low beams as the DRLs, just as if you have DRLs enabled on a US spec car and it's dark outside.<p>Do you have to do any software upgrade to install Euro lights? <br>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">Mine were silver not black, you lose all DRL's...period.<p>The Euro light has no DRL function, if it goes to a country that requires DRLs then I believe Volvo installed the US style light on those cars</TD></TR></TABLE><p>JRL is right.<p>if you look in the lighting threads there were posts by Jim Lill that indicated you could modify the wiring though to hook up the aux hi-beam as a drl. He also mentioned that it would be possible to adjust brightness of that hi-beam when used as DRL with some resistors. I don't recall all the specifics but read the lighting threads, there might have even been a wiring diagram there as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>FastWgn</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Do you have to do any software upgrade to install Euro lights? </TD></TR></TABLE><p>yes, to disable the drl i believe, get a code once on dash and clear it, it should stay cleared after that point.
Re: Question for people with Euro lights (atacamaR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>atacamaR</b> »</i></TD></TR><TR><TD CLASS="quote"><p>if you look in the lighting threads there were posts by Jim Lill that indicated you could modify the wiring though to hook up the aux hi-beam as a drl. He also mentioned that it would be possible to adjust brightness of that hi-beam when used as DRL with some resistors. I don't recall all the specifics but read the lighting threads, there might have even been a wiring diagram there as well.</TD></TR></TABLE><p>I did read most of them. Hence I have decided to not try to do the DYI version - seems very advanced! At the same time - $3,000 is a lot for a set of headlights...<br>This is very interesting though, since it implies the Swedish spec cars did not have the better high beams. Seems odd...<br>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>atacamaR</b> »</i></TD></TR><TR><TD CLASS="quote"><p>yes, to disable the drl i believe, get a code once on dash and clear it, it should stay cleared after that point.</TD></TR></TABLE><p>Got it - thanks. Shame since I actually like the DRL function. I guess I have to choose between DRL and good high beams. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>FastWgn</b> »</i></TD></TR><TR><TD CLASS="quote"><p>I did read most of them. Hence I have decided to not try to do the DYI version - seems very advanced! At the same time - $3,000 is a lot for a set of headlights...<br>This is very interesting though, since it implies the Swedish spec cars did not have the better high beams. Seems odd...</TD></TR></TABLE><p>i hear ya,i haven't done it myself yet either due to cost. I had a quote for getting them shipped here through the dealer back in March, was 2800 for 2 lights + shipping and tax. Thats slave or angle gear repair... but driving outside the city sucks at night...<p>i just wish there was an easier way to do upgrade these lights. I like the drls since i never have to turn my lights on but have a hard time pulling the trigger on spending that kind of money to get better brights and then modify them right away by changing wiring and painting them. I might end up picking a used set of us spec ones and attempting to modify them in spare time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>FastWgn</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Got it - thanks. Shame since I actually like the DRL function. I guess I have to choose between DRL and good high beams. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> </TD></TR></TABLE><p>No you don't. Just leave the headlight switch in the "on" position. There's your DRL. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: Question for people with Euro lights (Warpedcow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Warpedcow</b> »</i></TD></TR><TR><TD CLASS="quote"><p>No you don't. Just leave the headlight switch in the "on" position. There's your DRL. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"></TD></TR></TABLE><p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <p>Seriously - this would imply the parking lights are on when you turn off the car though, right?<br>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>FastWgn</b> »</i></TD></TR><TR><TD CLASS="quote"><p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <p>Seriously - this would imply the parking lights are on when you turn off the car though, right?<br></TD></TR></TABLE><p>No, why would you think that?<p>In non-xenon equipped Volvos of recent vintage, the DRL's are the stock low beams. The headlight switch doesn't do squat, except to cancel the highbeam feature in the off position.
Re: Question for people with Euro lights (Needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"><p>No, why would you think that?<p>In non-xenon equipped Volvos of recent vintage, the DRL's are the stock low beams. The headlight switch doesn't do squat, except to cancel the highbeam feature in the off position. </TD></TR></TABLE><p>Unless you're intelligent enough to have the DRLs turned off<br>(One can always leave the headlights in the on position, same results as if you have DRLs)
Discussion Starter · #14 ·
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"><p>No, why would you think that?<p>In non-xenon equipped Volvos of recent vintage, the DRL's are the stock low beams. The headlight switch doesn't do squat, except to cancel the highbeam feature in the off position. </TD></TR></TABLE><p>OK. I can't recall to have ever turned the car off with the light switch in the on position. I thought maybe the parking lights woudl remain on. Thanks for clarifying. In that case I should be in good shape, just always leave the switch in the on position.
Discussion Starter · #15 ·
JRL,<p>Any chance you have the part number for the Euro lights?<br>
(30698819, 30698820)
When you put those part #s in trademotion's website they show a price of $800+ for each one.
Re: (johnauten)
I lived in Sweden back in the late '70s and they had DRL's at that time. I'm surprised that they did away with it now.
Discussion Starter · #20 ·
Re: (johnauten)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>johnauten</b> »</i></TD></TR><TR><TD CLASS="quote">When you put those part #s in trademotion's website they show a price of $800+ for each one.</TD></TR></TABLE><p>Interesting - that is more reasonable than $3k! <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
1 - 20 of 39 Posts
