How are many of you doing the clutch install without the Clutch tool ?
I'm doin one in a 00 540i which has the dual mass & SOC system. . . . .trying to figure out if it's the same tool. Thanks in advance.
..........Dave
i have changed clutch and flywheel on my s60 2.4t and clutch on my girlfriend s60 t5 without problems. tried to ask around why you need the tool but i get no good answear.
2.4T have been driven 62137 miles since clutch and flywheel replacement
the t5 have been driven abouth 15000 miles,
all good.
If you carefully tighten the cover bolts in an alternate cross pattern you stand little chance of causing the self-adjusting cover feature to go wonky. Using the cover compressor and reset ring assures these things don't happen if you are careless.
all good.
Do both run a dual mass flywheel with the SOC system ? or the standard clutch system like an 850R ?
