· Registered
hi ! i've got a 2004 s60r and i want to upgrade the engine and exhaust
i wnat tu buy Tme parts (i'm French and it's easier for me and cheaper )
but i need advices because i want to buy the tme catback first but in second what is the best way ?
the DP then directly the tme/ipd stage 2
or
the stage1 then the stage 2 and the Dp
is it possible to drive with the DP with the stock ecu ? (without engien problem !!)
can you help me please ?
thanks
· Registered
Re: question about s60r engine upgrade upgrade !!! (frenchs60r)
Yes you can drive with the Down Pipe on the stock ECU software without engine problems. http://********************/smile/emthup.gif
If you want to upgrade go straight to the Stage 2 once you have the DP... then add the exhaust or do the full system and then go with the Stage two. http://********************/smile/emthup.gif
