With my brother helping me out, we changed my front brake pads today (rears were still good) and flushed my brake lines using the old-fashioned brake pumping technique. We then got up the courage to go for the clutch line and flush it as well - I know it probably should have been done first, but too late for that. It did not take long for the clean fluid to flush through and replace the old stuff, especially considering we were not getting very much fluid out with each clutch pedal pump.
Our question is this: when flushing the clutch, is the goal essentially just to flush the line leading to the flushing nipple (hence not needing much volume), or is there a way to flush more which would be flushing fluid out of the clutch housing itself? In other words, is it OK that we stopped when we saw the new fluid coming through or should we have flushed thorugh a much larger volume? We have to do his car next, so we need to figure out whether he will need more fluid than I used.
(Oh, and after we finished with the clutch, we went back and did a quick flush of a couple of the brake lines again to make sure we didn't introduce any air in case the clutch should have been done first - all looked good. Does the order matter much?)
Thanks in advance.
Albert
Thanks in advance.
Albert
