1 - 20 of 89 Posts
<A HREF="http://www.quaifeamerica.com" TARGET="_blank">http://www.quaifeamerica.com</A>/<p>anyone played with one of these?
Re: Quaife differential? (R_Rated)
Had one in a 1998 Porsche Turbo, they work well with early Porsches that have a lot of hp but have no idea about any other cars
How would this affect the R? We already can't spin the tires in straight line acceleration which causes the dreaded bog, wouldn't this just perpetuate that issue?
Most differentials help to get the power to the ground more efficialtly. My tires do/can spin through 3rd in a straight line. On a stock R a differential is pretty pointless as there are mods that will make so much more of a difference on a stock R.<p>The R32 is haldex AWD and when you thave the "AWD tune" the car drives better... even though it is alraedy awd and "the tires don't slip".<p>I am just wnadering is any R owners ahve done this yet so they can give me a heads up on any suprises they may have found.
Re: (R_Rated)
My AWD Talon had a limited-slip diff in the rear, although it was a different type (viscous, not gleason/torson). The car had a noticiable RWD-feel in the snow, but like R, wheel spin in the dry was not an issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>R_Rated</b> »</i></TD></TR><TR><TD CLASS="quote">...anyone played with one of these?</TD></TR></TABLE><p>That's the same as the "Torsen" differentials Audi uses in their "Quattro" AWD when the engine is longitudinally mounted. Fully mechanical and instant response (as opposed to Haldex). <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <br>
Re: Quaife differential? (ljjones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ljjones</b> »</i></TD></TR><TR><TD CLASS="quote"><p>That's the same as the "Torsen" differentials Audi uses in their "Quattro" AWD when the engine is longitudinally mounted. Fully mechanical and instant response (as opposed to Haldex). <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <br></TD></TR></TABLE><p>Isn't the Haldex in the R predictive to some degree? Isn't it tied into the same sensors as the 4C to adjust power distribution before any slippage at all? This is what Volvo claims. When I got my car, I thought it was a line, so I put it through one or two tests to see, and I felt it responded better than a diff would.
Re: Quaife differential? (JOSBRO)
This is what I thought too. However, I have very little education/experience with the technical end of AWD, so I was hoping that someone with a little more knowledge would chime in and give the pros and cons of a system like this vs. the regular old Haldex system we have.
Have one in a modded 2001 GTI 1.8T running 411whp. Can spin the tires up to third gear, keeps the car in a straight line. Nuff said. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: Quaife differential? (ReVolvR)
I detect a little confususion here. The Quaife differential is a Gleanson/Torson type of differential, as opposed to the common clutch-type or the less-common viscous type. Each type has different torque transfer characteristics, which can be discussed if we really want to get that geeky. <p>In an AWD car, it can be used in one, two, or all of the following locations...<p>Front axle<br>Rear axle<br>Between front and rear <p>In the R, the front/rear torque split is handled not by a "differential" in the strict sense of the word, but by an electronically-controlled clutch pack ("Haldex"). Side-to-side torque transfer (both front and rear) is accomplished by electronically applying the brake on the spinning wheel ("TRACS").<p>You could theoretically use a mechanical differential (e.g., Quaife) to replace Haldex and/or TRACS. I don't think the cost-vs-benefit equation would be favorable though.<p>How the heck do you pronounce "Quaife" anyway? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JOSBRO</b> »</i></TD></TR><TR><TD CLASS="quote">Isn't the Haldex in the R predictive to some degree? Isn't it tied into the same sensors as the 4C to adjust power distribution before any slippage at all? </TD></TR></TABLE><br>Yes, because it is electronically controllable, the computer can engage/disengage the rear wheels based on things <I>other than </I>wheel slip, like acceleration or deceleration forces. They do this to alter the handling characteristics (understeer/oversteer) in the various stages of a corner (braking into the corner, steady-state cornering, accelerating out).<p>This is not possible with a mechanical center diff. <p>Whether it's <I>good </I>or not is a matter of debate.
so no one has done this on an R? or experimented with this?<p>I am not wanting to know if people think this will or wil not work in theory. I appreciate your thoughts but U am really just looking to see if I can learn from experience and hopefully not mistakes.
Re: Quaife differential? (Dyno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Dyno</b> »</i></TD></TR><TR><TD CLASS="quote">I You could theoretically use a mechanical differential (e.g., Quaife) to replace Haldex and/or TRACS. I don't think the cost-vs-benefit equation would be favorable though.<p>How the heck do you pronounce "Quaife" anyway? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p></TD></TR></TABLE><p>More than thoretical - the Quaife is a limited-slip differential and benefits the drive wheels a LOT. In a FWD car with high torque they make a huge difference, used on race cars, etc.<p>The existence of a front-differential for the S40 and S60 here is news. Previously, Quaife listed a rear diff for the S60, which is interesting but how often have you broken away a rear in the R? I think a front LSD would reduce TRACS events, and would therefore make the Haldex more for balance than traction. This would be good!<p>Someone should contact them to see whether this front diff is an AWD diff, or FWD. They're different, and if FWD-only, obviously incompatible with the R (and my V50 <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> ).<p>BTW, I have heard it as "koo-way-f" (silly spelling to make soft q).<p>Tom.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Dyno</b> »</i></TD></TR><TR><TD CLASS="quote">...How the heck do you pronounce "Quaife" anyway? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"></TD></TR></TABLE><p>I'll make a guess: Like "coffee", but with a "w" in there -- "cwoffee".<p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
Re: Quaife differential? (tmtalpey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>tmtalpey</b> »</i></TD></TR><TR><TD CLASS="quote">I think a front LSD would reduce TRACS events, and would therefore make the Haldex more for balance than traction. This would be good!.</TD></TR></TABLE><br>I agree that in a race situation, it would be a good thing. I can't see how appying the brakes (as with TRACS) can <I>ever </I>be a good thing if you can avoid it (as with LSD).<p>If you only have one place to put it, I'd think you'd want it on the rear. Otherwise it would be an understeering pig when you get on the gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>tmtalpey</b> »</i></TD></TR><TR><TD CLASS="quote"><p>More than thoretical - the Quaife is a limited-slip differential and benefits the drive wheels a LOT. In a FWD car with high torque they make a huge difference, used on race cars, etc.<p>The existence of a front-differential for the S40 and S60 here is news. Previously, Quaife listed a rear diff for the S60, which is interesting but how often have you broken away a rear in the R? I think a front LSD would reduce TRACS events, and would therefore make the Haldex more for balance than traction. This would be good!<p>Someone should contact them to see whether this front diff is an AWD diff, or FWD. They're different, and if FWD-only, obviously incompatible with the R (and my V50 <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> ).<p>BTW, I have heard it as "koo-way-f" (silly spelling to make soft q).<p>Tom.</TD></TR></TABLE><p>Quaife is offering a front diff for the S40 with the M56 gearbox. This diff fits all M56 gearboxes also used in the 850 and classics and the 5 speed S60/V70N.<p>When ordering nothing is possible, they don't know poop about what they are selling, they think customers will wait 3 months or more and you'll need to order 30 pcs in once.. <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> <p>Personally I would like to see an lsd in the rear. Front spin will activate the rear, spin after that activates the tracs, tracs shuts down when to hot leaving you with a spinning inner rear wheel wehn things get rough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ljjones</b> »</i></TD></TR><TR><TD CLASS="quote"><p>I'll make a guess: Like "coffee", but with a "w" in there -- "cwoffee".<p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0"> </TD></TR></TABLE><br>How the heck to you think you could pronounce it? No, it's not what you said<br>(Question was answered correctly above) but you (like my wife), would go out of your way to try and find a pronounciation that makes no sense to anyone. "qu<B>ai</B>" cannot sound like "qwaf"<br>Perhaps you think it sounds like an exotic hairdo, like Qwa-faye? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <br>It's Kwayf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Dyno</b> »</i></TD></TR><TR><TD CLASS="quote">If you only have one place to put it, I'd think you'd want it on the rear. Otherwise it would be an understeering pig when you get on the gas.</TD></TR></TABLE><br>Yep! That's what I was saying - with both fronts pulling, there would be less slip, ergo no TRACS. The Haldex controller would see the throttle go down and engage torque for the rears, off you'd go on all four. Well, technically, three. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> That's what the rear Quaife would be for. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <p>You can't avoid torque to the fronts. There's no "center" diff, the front diff is inside the trans.<p>Tom.
Re: Quaife differential? (Johann)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Johann</b> »</i></TD></TR><TR><TD CLASS="quote">Personally I would like to see an lsd in the rear. Front spin will activate the rear, spin after that activates the tracs, tracs shuts down when to hot leaving you with a spinning inner rear wheel wehn things get rough.</TD></TR></TABLE><br>They list that! "S60 rear". Of course it also says "please call".<p>Interesting point on the rear TRACS shutting down, yes it would help that.<p>Tom.
1 - 20 of 89 Posts
