1 - 9 of 9 Posts
I have been reading about these alot recently. after see something on the c30 forum and reading the new euro focus st has one. being a total newb. can i install one on my automatic. if not is there anther option.
For reference...<p><A HREF="http://www.quaife.co.uk/Volvo-S40-M56-front-ATB-differential" TARGET="_blank">S40 T5 Quaife Differential</A>
Re: Quaife Differenntial (kpsingh0)
The LSD is intended for a manual trans not an automatic. If you were looking to do some sort of trans upgrade you would have to look into aftermarket internals which sounds like uncharted territory for volvos. Doesnt sound like to many people have done a lot of auto trans upgrades. There may be shift kits and valve body assembly upgrades available but i wouldnt know who thru and how much.
i remember we had a similer if not same trans as the s60. so maybe i sould look tat direction. i was trying to lose some tourqe steer tho.
Its really not uncharted territory there are so many mods to these cars its unreal. <p>You just need to look back at the 850/7xx volvos. Most parts are carry overs (like the engine and trans and if not the same very similar)<p>The auto trans is Aisin made, popular with toyotas. That should open some options.
Why do you want to upgrade the tranny anyway?
I know where he's coming from. <br>In the auto wheel spin is epic, a real problem. Dam torque multiplier, makes it dam near impossible to drive aggressively. <p>Update on Trans. We use the Asin AW55-50 on FWD and AW55-51 on the AWD (very similar trannys), also used in the Xc70, Xc90, S60, V70, C70, S80, S90 and the old S40. So the parts are very available. <p>Slightly modified but still Aw55-50's are also used by other manufactures. Saab uses them in the 9-3 and 9-5. The internals are used in the Saturn Ion Vue as the AF23-5 and the AF33-5, in the Chevy Equinox as the AF33-5, and in the Nissan Altima, Maxima, and Quest as the RE5F22A.
Re: (zerocover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zerocover</b> »</i></TD></TR><TR><TD CLASS="quote">I know where he's coming from. <br>In the auto wheel spin is epic, a real problem. Dam torque multiplier, makes it dam near impossible to drive aggressively. <p>Update on Trans. We use the Asin AW55-50 on FWD and AW55-51 on the AWD (very similar trannys), also used in the Xc70, Xc90, S60, V70, C70, S80, S90 and the old S40. So the parts are very available. <p>Slightly modified but still Aw55-50's are also used by other manufactures. Saab uses them in the 9-3 and 9-5. The internals are used in the Saturn Ion Vue as the AF23-5 and the AF33-5, in the Chevy Equinox as the AF33-5, and in the Nissan Altima, Maxima, and Quest as the RE5F22A.</TD></TR></TABLE><br>exactly <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <br>by the way i can't find anything? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <BR><BR>
<i>Modified by kpsingh0 at 9:40 AM 4-7-2009</i>
Re: (zerocover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zerocover</b> »</i></TD></TR><TR><TD CLASS="quote">I know where he's coming from. <br>In the auto wheel spin is epic, a real problem. Dam torque multiplier, makes it dam near impossible to drive aggressively. <p>Update on Trans. We use the Asin AW55-50 on FWD and AW55-51 on the AWD (very similar trannys), also used in the Xc70, Xc90, S60, V70, C70, S80, S90 and the old S40. So the parts are very available. <p>Slightly modified but still Aw55-50's are also used by other manufactures. Saab uses them in the 9-3 and 9-5. The internals are used in the Saturn Ion Vue as the AF23-5 and the AF33-5, in the Chevy Equinox as the AF33-5, and in the Nissan Altima, Maxima, and Quest as the RE5F22A.</TD></TR></TABLE><p>Or you could just learn how to regulate the foot....<p>My best 60ft was sitting right between 2.1-2.2 consistently over 4 or 5 runs last time I went to the track, which is not bad...at least I don't think it's that bad.
1 - 9 of 9 Posts
