1 - 6 of 6 Posts
how do i put fluid into a dry transmission on a 1999 v70 xc?
I think you're supposed to at least fill the torque converter before install
how would you get fluid in there? does anyone have another opinion on how much fluid it takes?
Note Jim said the before install... I assume you already had fluid in it since u bought the trans used. Check your manual it should tell you how much it takes. Put in like 2 quarts less than what it says and run it through the gears and then leave it running let it warm up and check the level... Top off to what is needed.
installed, it shows decent level of fluid now to since i pulled it off a running vehicle.
1 - 6 of 6 Posts
