1 - 20 of 26 Posts
Lighting. At certain moments it can the difference between a trip to the body shop or just an elevated heart rate and sweaty palms. Good lighting is invaluable for safe driving and Volvo, known for its safety innovations, has incorporated their bi-xenon lamps into several models since 2002.
Full Story
Re: Project V70R: European Bi-Xenon Headlight Upgrade ([email protected])
My biggest grip comes from the Low Beam performance, in terms of distance or length of the beam. It seems very short, especially when travelling at high rate of speed.
Any suggestions? And what can one expect from the new Euro lights, what's difference btw the US factory ones.
Are regular S60 Bi-Xenon's compatible? What about the other way around, can R headlamps work on regular S60s?
Re: Project V70R: European Bi-Xenon Headlight Upgrade (R_Rated)
Too bad they finally came out with a projector beam setup for '07 which is far superior to the reflector models you guys installed...but either way, a certain improvement over the N.A. versions.
Administrator
Re: (slowrey)
Quote, originally posted by slowrey »
So does this incorporate the halogen hi beam and get rid of the DRL? If so do you get the DRL bulb failure notice?
The euro lights incorporate a halogen bulb for hi-beams - the entire North American lens is replaced with the euro lens so the DRL no longer exists. A VIDA/VADIS software update is required to disable the DRLs.
Hope that answers your question.
Re: (martynunya)
Quote, originally posted by martynunya »
When you flash the high beams, is the initial response from the supplemental lighting quick or is it delayed like the main beam?
Halogens are instaneous, xenons elevate at same speed as US Spec.
Chris, you HAVE to get some silvervision or stealthauto turn signals. I get hungry for an omelet every time I see those.
Re: Project V70R: European Bi-Xenon Headlight Upgrade (r_driver04)
Quote, originally posted by r_driver04 »
Just adjust the headlights up. It's very easy. I did one complete turn (360 degrees) on the adjustment nob. I'm happy with the headlights.
As for the Euro spec lights, too expensive at $2200 in parts alone.
Administrator
Re: Project V70R: European Bi-Xenon Headlight Upgrade (flybynight)
The price has gone up considerably since I purchased them from Kelly.
Re: (slowrey)
I wish you could turn off the DRL's on the MY04
You can and you know it.
Mine have been off for 3 years, this has been discussed ad nauseum
Re: (JRL)
Actually, I didn't know it. I've tried multiple times to get mine done at the dealership and they told me NO.
I personally thought JRL that you got yours done because you knew someone who knew someone.
http://forums.swedespeed.com/zerothread?id=17816
I Haven't left yet, (Thurs)
As I've told Jim Lill and others, this was done as a favor to me and for some strange reason Volvo will NOT do it for the general consumer.
I don't know why they have this policy and I couldn't get a straight answer from anyone about it.
The codes were in the factory reps laptop, not in the dealer's Vadis so you won't be able to have it done.
Sorry.
JRL
and
For For the last time, yes, but you can't!
They won't do it for you,
again, sorry
JRL
Quote from Full Story:
"There is probably a U.S. regulation somewhere that requires Volvo to deactivate the supplemental high-beam found in equivalent European units, which may explain the difference."
I doubt that, as my 2005 Lexus LS430 has Xenon Low Beams with supplemental halogen high beams. Both Xenon and Halogen work together on the High Beam setting. For DRLs, high beams are on at greatly reduced power, which explains why they look a yellow/amber color during the day.
I wonder why Volvo didn't just program the European halogen high beams to run at 1/2 power for DRL use in North America?
My intention is not to be a jerk however, with the 2004 it's been clear as mud if they can be done. The only person I know of that got em' done was JRL who emphatically stated that his was a custom one off.
JRL can you help me out and relub whomever you got to do yours so they can get mine done too?
Re: (slowrey)
wrxownr also got his '04 done somehow in England, I've asked him to get details from his dealer.
Re: (JRL)
Turning off the DRL's is just a matter of a software download (upgrade to the CEM - Central Electronic Module - parts and labor!). I just walked out to a bunch of our techs and they all knew about it - one had just done this to a customers car today.
Quote, originally posted by MAC1LSR »
When car makers started cutting out the low beams in the early 1990's, I had heard that it was an effort to cut down on the alternator power and therefore size.
John
1 - 20 of 26 Posts
