By mistake I erased all of the codes on my garage door opener. I have followed the owners manual and am not able to re-program the Homelink. The manual states that to program a "rolling code" opener:
1. Clear out the old codes from the home link.
2. Press the learning button on the garage door opener (gives a 30 second learning window)
3. Press the desired Homelink button for 2 seconds and then release it. This may have to be done up to three times in within the learning window.
I have followed the above steps and the Homelink is not taking.
My question is do I need to do the remote receiver programming steps first or should it work by using the rolling code process only.
The remote receiver process is where you hold it within 3 inches of the Homelink visor and simultaneously press it and the desired Homelink button.
The remote receiver process was what I had to do. It only took one try.
In my experience it was one or the other, not both. Standard method did not work, so I used the rolling code method. Had to clear it first, then it worked per the instructions.
Thank you both.
I will try the second method again.
