1 - 9 of 9 Posts
Thought i would start one - could not find one using the search feature. I will as people post.
COMMON ONES:
Suspension - sway bar/tie rods
T6 Engine - AVOID FROM PURCHASING USED.
Modified by jnusaputr at 2:53 PM 3-21-2009
Re: problems areas for xc90 (jnusaputr)
Wheel bearings?
Re: problems areas for xc90 (855turbo95)
Quote, originally posted by 855turbo95 »
totally different engine.
and more importantly........transmission
Quote, originally posted by jnusaputr »
COMMON ONES:
Can't say the 'sway bar' itself is a common issue but the end-links sure do wear out often. Control arm bushings also wear out pretty quickly.
Wheel bearings...
Explain please
... water ingress in the rears. It's very common in northern climates (ie cold, damp months). All P2 volvo's are susceptible.
Another less common issue, also in cold damp climates, is with the fuel pump control module that dies from a corroded connector, the fix is with a new part and harness that relocates the module to INSIDE the vehicle (similar to a known issue with the V&S40).
LTA
1 - 9 of 9 Posts
