· Registered
Hi,
this is my first post.
Im the owner of a 1988 740 turbo with the 4speed manual with overdrive.
but the previous owner have made some change of the tranny stick and put a custom button for the o/d. now it doesn't work.
what i can check for that? fusebox? the button work. ive tested it!
maybe if i post picture of the current setting, it will help me, but if ppl know about this kind of tranny for what i must check..
thanks.
http://********************/smile/emthup.gif
· Registered
Re: problem with o/d on a 4speed manual (gdill2)
thanks.
EDIT: Ok, i have called a volvo garage near me.
the cost for this relay are too high! but i need one!
does he have a way to test if the relay is the problem?
on the web site, he didn't talk about the relay test.
Modified by volvoid at 10:13 AM 5-10-2006
· Premium Member
Re: problem with o/d on a 4speed manual (volvoid)
A faulty relay may work ok one time and not the next.
Other areas to check are ALL electrical connections and grounds and all switches associated with the OD including the solenoid.
George Dill
