1 - 2 of 2 Posts
I own a 1997 volvo v40 and i have problems getting into the 1st and 2nd gear and reverse. In fact now i have to use the pull lever on the gear stick (normally used to go into reverse) for the 1st and second gear. also when in gear the gear stick is very soft as in i can shake it side to side as if i was in neutral. can anyone help? <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Discussion Starter · #2 ·
Re: Problem changing gears (thugusher)
Problem now sorted... Got my trusty mechanic to check my car and he said that the car had just recently had a new clutch and gearbox fitted to he just lined up the clutch properly (as this wasn't correctly in place) and voila i can change the gears fine now... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
1 - 2 of 2 Posts
