Hello all,
Last year, my son bought a 1987 245 in very good condition. One reason it was in very good condition is that it had sat for most of the past ~15 years since its owner moved to New England, so there is very little in the way of corrosion. On the other hand, we're finding other things that need help that are typical for a car that hadn't moved much (a couple days after he bought it, the rubber fuel line section from the tank burst, and just recently we were surprised by the rear cam seal on the valve cover popping out and causing a good mess). We've got very good service records going back to the early 1990s, with the last major work before he bought it happening in early 2021 on the fuel system.
So far beyond oil changes and lube, work we've done:
Engine:
Running Gear:
Electrical:
Misc:
Parts on the way or in hand:
Contemplated projects:
Far future projects:
So finally to the questions.
Thanks in advance!
Engine:
- Replaced Exhaust/welded y-pipe, replaced gasket.
- Replaced/relocated flame trap
- Replace Rear cam/cover seal (added IPD retention device)
- Replaced valve cover gasket
- There's a trace of surface corrosion on the cam we noticed when we opened up the valve cover, so we're planning on oil changes every 1k for a while, and next one we'll put in a magnetic plug to help keep an eye on things.
Running Gear:
- Replaced Front/rear brakes
- Replaced Master cylinder
- In the process, pumped a solid half-gallon or more of DOT 4 through the lines as there was some debris
- Replaced rear springs (IPD +300lb)
Electrical:
- Replaced headlight relay
- Replaced bulb failure relay
- Replaced odometer gear
Misc:
- Wiper blades
- Winter wheels/tires
- Fix some small stone chips/treat corrosion
- Timing belt/tensioner (last done a decade ago, and odometer was nonfunctional - estimate ~15k since then)
- Fuel filter
- Upgrade anti-sway bars
- Replace shocks
- Motor/transmission mounts (look OK but worn)
- AC troubleshoot/fix
- Replace coolant/oil/steering/fuel hoses (most look good from outside and seem pliable, but don't want surprises)
- Clean window lift gear - fronts run pretty slow
- Pull/replace rear window (a little rust starting near seal on bottom)
- See if we can fix the heated seats
- What else would you recommend we do soon?
- Any recommendations on which IPD sway bars to go with, and shocks? While he's a young, hard-charging kid, he drives more like a grandma, so we're not looking to make it into a track car. But he does load it up often with friends and skiing/biking/hiking/camping gear in the back/on top.
- Recommendations for good, heavy-duty rubber floor mats with a lip on them? The ones IPD sells seem to have positive reviews for the fronts, not so much for the rears. WeatherTech is usually my go-to, but they don't list them for the 240.
Thanks in advance!
