1 - 12 of 12 Posts
Hi guys. My slave is leaking and I wanted to take advantage of this to freshen up on a few other parts and fluids while I'm in there. Right now I'm thinking:<p>Slave cylinder<br>Clutch kit<br>Flywheel<br>Rear main seal<br>Angle gear collar (I'm assuming the shaft needs to come off for the job)<br>Motor/Transmission mounts (still debating these)<br>Transmission fluid<br>Angle gear fluid<br>Brake fluid<p>Am I missing anything? Even if I don't use all the parts, depending on their condition once I get in there, I'd like to have them on hand, just in case.
Re: Preparing for Slave Cylinder Job - What other parts should I do while in there? (S60R1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>S60R1</b> »</i></TD></TR><TR><TD CLASS="quote"><br>On the angle gear collar, do any of you know the P/N to the upgraded/stronger collar that volvo had in later years, IIRC 06-07 GT's, and confirm that it's a drop-in replacement on my 04? </TD></TR></TABLE><p>You won't be able to use the 06/07 GT collar gear, not a direct fit<p>However Volvo did upgrade the MT part (nitride coating) it is not chuck norris, but it is better than the old one. New part number is 31256008
Re: Preparing for Slave Cylinder Job - What other parts should I do while in there? (FEO)
^^ I juuuust finished deleting that part of my original post because I got your e-mail lol<p>You said it was a direct fit though. The autos had different teeth on the collar? Weird.<p>Thanks for the P/N btw! <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
new "upgraded" MT part, direct fit to old MT part <p>few things are more confusing in life<p>bottom line, order 31256008, it will be <i>somewhat</i> of an upgrade over the old part
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>FEO</b> »</i></TD></TR><TR><TD CLASS="quote"> it will be <i>somewhat</i> of an upgrade over the old part</TD></TR></TABLE><p>I.E. you will get ~70K miles with it lol.
Re: Preparing for Slave Cylinder Job - What other parts should I do while in there? (mpdbrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>mpdbrown</b> »</i></TD></TR><TR><TD CLASS="quote"><p>I.E. you will get ~70K miles with it lol.</TD></TR></TABLE><p>86k on mine and fine.<p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0">
Re: Preparing for Slave Cylinder Job - What other parts should I do while in there? (Needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"><p>86k on mine and fine.<p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> </TD></TR></TABLE><p>you are GT<p>Those fail very rarely in 04-05s and never in 06+s<p>My theory is that the transmission juices absorb some of the impact...actual torque is ok on the part...impact is what kills it<p>also, they are torque-limited or were for a good chunk of their life <p>
Speaking with two of my favorite techs this morning, the Air Vent Pipe should be replaced along with the other clutch pieces:<p><IMG SRC="http://images51.fotki.com/v1547/photos/1/10538/4523694/RClutch-vi.gif" BORDER="0"><p>This piece connects directly to the slave cylinger/throw-out bearing and the hydraulic hose that goes to the clutch master cylinder.<p>They also mentioned bleeding the clutch line of all air. They said that sometimes they leave the rear of the car lifted all night in order to get all of the air out. They also said that Volvo's special tool is needed to properly pre-load the pressure plate. I counted five Volvo special tools needed for a clutch replacement in the VIDA software.<p>John<p><i>Modified by Parts @ Boston Volvo at 7:36 AM 7-16-2009</i><BR><BR>
<i>Modified by Parts @ Boston Volvo at 7:38 AM 7-16-2009</i>
Re: Preparing for Slave Cylinder Job - What other pa ... (Parts @ Boston Volvo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Parts @ Boston Volvo</b> »</i></TD></TR><TR><TD CLASS="quote">They also said that Volvo's special tool is needed to properly pre-load the pressure plate. I counted five Volvo special tools needed for a clutch replacement in the VIDA software.<p>John<br></TD></TR></TABLE><br>Tools<br>1: engine support(could make your own for about $30)<br>2: gear shift cable puller(just use your hands)<br>3: left axle jimmy (breaker bar works just as well)<br>4: Special jack w/ subframe support attachment (I used a regular jack w/ a piece of wood)<br>5: ball joint separator fork + protective boot (not necessary)<br>6: Transmission jack adapter (could get away without it)<br>7: counter hold for driveshaft to angle gear bolts if completely removing angle gear (could easily fabricate your own)<br>8: Clutch pressure plate compression tool + counter hold tool(to pre-load sac pp)..............<br>..........see this thread:<p><br><A HREF="http://forums.swedespeed.com/zerothread?cmd=print&id=77933" TARGET="_blank">http://forums.swedespeed.com/z...77933</A><p>9: clutch alignment tool (could find a universal one, or just do it by eye)<br>....I'm sure I'm forgetting something, but as you can see, you could get away without many of these "special" tools...you just gotta be a little creative(like McGuyver <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> )<p>Also, don't forget various hardware. subframe bolts(2 diff part#'s, 4x each), engine mount bolts, prolly new control arm hardware(if removing it completely), new pressure plate bolts(6x), plus any other bolt that might be slightly damaged when disassembling. Other optional ones: input shaft seal, and flywheel bolts.
Re: Preparing for Slave Cylinder Job - What other pa ... (rushin_max)
^^ wow, very good stuff from everyone. I'm going to start a parts list <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> there's no way I'll remember everything lol<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>FEO</b> »</i></TD></TR><TR><TD CLASS="quote">...it will be <i>somewhat</i> of an upgrade over the old part</TD></TR></TABLE><p>I'm actually afraid of doing the collar, because if my original one has held on for 97k miles with spirited driving and launches, should I really replace it? The thing might be caked on solid as a rock. Then again, it might be on its last legs too. I think my plan will work here, have all parts on hand and decide what to replace upon a visual inspection. Oh boy.
Re: Preparing for Slave Cylinder Job - What other pa ... (S60R1)
I wonder if the "dashpot" needs to be bought separately. According to Volvo, it is included with the purchase of the slave cyl/TOB <p><A HREF="http://forums.swedespeed.com/zerothread?id=119058&postid=1268396" TARGET="_blank">http://forums.swedespeed.com/z...68396</A>
Re: Preparing for Slave Cylinder Job - What other pa ... (FEO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>FEO</b> »</i></TD></TR><TR><TD CLASS="quote">I wonder if the "dashpot" needs to be bought separately. According to Volvo, it is included with the purchase of the slave cyl/TOB </TD></TR></TABLE><p>John at BVV is checking into it <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p><br>EDIT: not included <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> maybe it needs more time for stock to push through.<BR><BR>
<i>Modified by S60R1 at 9:57 AM 7-17-2009</i>
1 - 12 of 12 Posts
