1 - 8 of 8 Posts
My power driver's side window motor fried up, so I need to replace it. I was told the part is like $340. Do you guys know where I can get it for a lot cheaper
I am telling the guy to just put the window Up, and I won't touch it for now...
Thank you guys.
Ciao
I've fixed my power window, however I smell it melting away again. I am not using it right now; do you guys know what could be causing this? I am bringing it back to the shop soon, but it would be helpful if I can steer the guys in the right direction.
Thank you guys.
Ciao
Re: (dicostal)
There could be an issue with the tracks or seals causing excessive drag on the window.
Does the glass move smoothly or is it a little bound up?
Motors should not cook unless they have a good reason.
Cheers,
Prospero
1 - 8 of 8 Posts
