Re: Power Steering Rough (jflowers1974)
If the fluid level has not changed and no leaks exist then check the drive belt for proper tension and the front tire pressure.
George Dill
Re: Power Steering Rough (gdill2)
Hello,
The fluid level is unchanged. I should note that I performed a flushing of the fluid about two months ago. This was done using by the turkey baster method, perhaps three/four time. Every time I refilled using Mobile 1 ATF.
The belts are fine. As well as the color, perfectly red.
There's no noise, and no weird vibrations during a turn.
Its just a not easy and effortless.
Sounds like air in the system. This will self-purge over time.
George Dill
