1 - 8 of 8 Posts
First time posting so bear with me. Long story short I had to get a reman rack put in my V70R and with new Lemforder outer tie rod ends. Problem Is I ran out of adjustment for toe, it is currently toed way in.
Question 1) I have done some research and I heard there is a possibility that the Lemforder tie rods could be too long
Question 2) Does anyone have the total length of the Power steering rack inner tire rod to inner tie rod?
2004 S60R & 2006 XC90 2.5T Real Volvos have 5 cylinders!!
I had the same issue and it turned out that I got the wrong outers from an online vendor.
The story I got was there were two different racks used for 2004. IDK, but the replacements they shipped worked.
There wasn't much difference in the two, it was hard to tell visually.
whats the part number of the ones you bought
CL to CL is 58-3/8" (1482.73 mm) for as-shipped new-in-box part number 36050368. Let me know if you need another dimension.
Awesome thank you for that, should get me into the ball park, but could you get the dimensions without the outer tie rods on? Thank you, it would be much appreciated!
Volvo Tie Rod End - Lemfoerder 30761719
S60, S80, V70
Part #: LEM-2667602
Sorry for the delay in reply! Here is the measurement from 1st thread to 1st thread. ~38-5/8" (981mm)
Thanks you! Got the new rack in and got my old rack back (couldn’t rebuild it bc the chrome on the ram is too pitted) and did some measuring. Thank you everyone for your help
1 - 8 of 8 Posts
