1 - 11 of 11 Posts
anyone xperience this...<br>pass.side power seat not working, switched out the #39 & 40 fuses..<br>no help...<br>i can only guess motor!...does it have 2 motors for the back & seat cushions, or the 1......<br>totally loss <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Re: power seat (volvoom1)
The switches go bad (very common), but<br><B>Check the switch connection,</B> I had one <B>come loose</B> on me and what you describe is what it sounds like.<br>If the entire switch took a crap you can buy a used one at <A HREF="http://www.erievovo.com" TARGET="_blank">http://www.erievovo.com</A> but I will bet the connection came loose because the entire switch usually doesn't go bad, neither does the seat. They have 3 motors, ONE function has to still work!forward, back, up, down or recline, something should still work
Re: (volvoom1)
Could be either, try the control first, easier to get to.<br>If it IS the switch I just happen to have a (good) right side switch I would sell you
Re: (volvoom1)
The plastic side panel of the seat removes quite easily. <br>When removed it all there for you to see what you need to do
Re: (volvoom1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>volvoom1</b> »</i></TD></TR><TR><TD CLASS="quote">let me know what yur asking for the switch,<br>so i can b prepared..</TD></TR></TABLE><br>Gees, haven't thought about it, say $75 if you need it which would include shipping.<br>(New switch is at least 2 to 3 times that)!!<br>Again, usually the entire switch doesn't fail, only one function, fore-back or tilt but not all three at once
thats what my problem is...<br>no functions at all, w/all fuses checking out ok<br>i just figured the motor went away
Re: (volvoom1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>volvoom1</b> »</i></TD></TR><TR><TD CLASS="quote">thats what my problem is...<br>no functions at all, w/all fuses checking out ok<br>i just figured the motor went away</TD></TR></TABLE><br>Fuses rarely go on a seat.<br>I still think you should have someone look at it first as they just don't quit all at once.<br>As I stated, one function starts to go first, front-back, up-down or tilt but for the seat to be totally dead just like that, doesn't happen.(Well, anything is possible with a Volvo but USUALLY that doesn't happen)<br>I'll be happy to sell you that switch but I really think that a mechanic should look at it first
1 - 11 of 11 Posts
