1 - 20 of 20 Posts
Is it possible to 'hot-wire' the lighter socket in an '06 V70R? My wife charges her phone a lot and it's a nuisance that it shuts off with the car. Actually, ditto for the power seat controls. Do the swedes have some irrational fear about dead batteries? Thanks...
Re: (R_Rated)
Quote, originally posted by R_Rated »
driver side is active on mine when the car shuts off. Mostly american cars the power outlet works when the car is off. Not many imports of any kind.
Actually, my VW, Saab, BMW and every Japanese car you can think of had/have these items available with the car off. Additionally, most European cars allow you to run the radio without the key even being in the ignition. That's why I find this car so strange.
Re: Power outlet.. (JimLill)
Quote, originally posted by JimLill »
both those items were covered back in 2003... may even be some you can find via the FAQ page
What do you mean by "covered"? My 2005 doesn't allow me to move the seats when the car is off.
Re: (speedemon)
Quote, originally posted by speedemon »
If you have the optional convenience outlet in the rear (not the back seat), it's powered all the time. You would need a long cig lighter extension cord though.
I have the cargo outlet. I installed it myself and it is only powered when key is on. During the install I had to run a new power cable for it from the Rear Elect module. After I ran it I realized there was already a power wire there. So I tried it and it didn't work. What gives. I used the new cable I ran and it works fine, but only when the key is in.
Re: Power outlet.. (Dashdog)
Quote, originally posted by Dashdog »
When it's 45C below (or -70 factoring in windchill) it IS a rational fear.
I guess if your battery is dead due to charging your phone at least your phone will be alive so you can call for help
LTA
2005 V70R, Midnight Blue, M66
Re: (JAGMAN)
I have an 2005 V70R with a factory power cargo outlet. The outlet is always ON.
If you remove the key, while there is still anything drawing current, (greater than approx. 100 mA), you will get this display in the DIM.
Modified by rogersampson at 5:57 PM 11-13-2006
Re: Power outlet.. (LTA)
Quote, originally posted by LTA »
LTA
Well LTA just gotta do what my brother-in-law did when he was living in yellowknife, wire a battery tender up to your block heater http://********************/smile/emthup.gif that way you should always be good to go.
As for the constant power argument, my VW has a power button on the stereo to run it without a key in the ignition, can't remember about my MB but I think it's the same story. However, what Jim Lill mean't was that back in 2003 these issues were covered on the forum, and may infact be in the FAQ, search, and make sure to select archived content. (sorry to be one of those gus, but hey, it works)
Re: (rogersampson)
If you R is still under warrany, this is probably a really
good question for your dealer...
There are several practical solutions to your problem,
but you might run into warrany issues...Not Sure...
If THEY do it, you've got documentation.
Uranus Protectus...
You'd think that they would have a solution for this.
I'm pretty sure that Swedes use cellphones.
They aren't that far from Fin-NOKIA-land.
Modified by BEJinFbk at 5:04 PM 11-13-2006
Re: (R_Rated)
driver side?
you have two sides?
Re: (speedemon)
not mine. both front and back shut off with the car.
Re: (TimBradley)
Quote, originally posted by TimBradley »
Ha. Just like the time of the original post - everyone has something to say about it, but no answer to the question at hand. Thanks anyway.
Here's the deal- Get a fuse holder, a couple of the appropriate connectors,
and some wire. Run a lead from the battery to cigarette lighter and, Voila!
That's the guerilla version. There is also an "Accessory" connector swinging
around under the dash that provides up to 20amps on the 98's.
I don't know if the tradion was continued in later years, but we older
R owners have the following:
Pin outs:
Connector (for accessories)
Position Connection Max. load
1 Battery + (30) 20 A
2 X Supply 0,5 A
3 High beam 1 A
4 1 A
5 1 A
6 Rheostat 0,5 A
7 2 A
8 Earth (31) -
From Page 105 of the 98 70 series owners manual.
You can find a constant 12 volt source in plenty of places,
just try to keep it safe, clean and fused at the source.
1 - 20 of 20 Posts
