1 - 20 of 34 Posts
Hey everyone. I just got my phuzzy dp installed and I wanted to see how everyone elses turned out. I am not sure mine was fabricated correctly and want to see how everyone elses lines up when installed.
I would really appreciate pics of the welds, and the exhaust hanger after installation. After a few others post up pics, and I can compare, I'd be happy to post some pics of my new dp and a clip of the dp and TME exhaust mated.
Also, how many of you installed gaskets on both the turbo and the cat back flanges?
Re: Post pics of your Phuzzy DP (PdangerP)
Not to threadjack, but I was doing my exhaust, and I thought the downpipe would be a real bitch to install. How is it?
Re: Post pics of your Phuzzy DP (Tiny)
Quote, originally posted by Tiny »
You need to remove the one bracket, and then pulling the stock DP out is fairly simple, as is re-installing the aftermarket DP. http://********************/smile/emthup.gif
Moderator
I was looking at the Phuz DP myself. I noticed that it comes with a cat.
Would it be possible to get a catless DP and in place of the second 02 sensor just put a sensor extender (the one from eBay) which eliminates the CEL?! has that been done before?!
Thanks
Quote, originally posted by PdangerP »
I did not use any gaskets. Installer was a little leary of this, but I have no exhaust leaks.
There will be a massive difference initially, because I think the flex pipe definitely needs to break in first. Let it heat cycle a few times and it will be fine.
Questions for you:
Did you remove your bracket?
Did your installer compare the stock and Phuz DP, or take some preliminary measurements first?
Did you put any gaskets on, and are the hangers level?
Why don't you post pics of yours now? It's your thread, you do it.
Re: Post pics of your Phuzzy DP (BeerEngineer)
Phuz installed mine since we live relatively close. The only two "issues" that came up was the hanger bracket being short on one side by like a 1/2" inch, and the bar did not extend completely out of the hanger, woopidy doo. Also, I had some vibration for the first day or so, then once the flex portion broke in, it fits like a glove http://********************/smile/emthup.gif
My Phuz DP is in my living room. My debate: Do I install now or when my VIP is done in 20,000 miles.... Hmm.
Re: (adykes)
Quote, originally posted by adykes »
Now!
It would be tough to deny a warranty claim for an engine related issue considering this is post-engine bolt-on.
Re: (adykes)
NOW! DUH! http://********************/smile/emthup.gif
Re: (phuz)
Quote, originally posted by phuz »
Now!
I know, but I also know my VCNA regional rep would find a way...
Re: (tomedkaz)
Quote, originally posted by tomedkaz »
Thanks
You can get a stock DP dirt cheap and knock out the catalyst (for of-road use, of course). Easy mod, and changing out DP's takes about 30 minutes.
Add the CEL eliminator and you won't get a CEL. It's an amazing difference - pulls all the way to red-line even when the temps are high.
Good CEL eliminator here:
http://www.inlinefour.com/blcelelad.html
Re: (tomedkaz)
So what's the difference between Phuz DP and de-cated OEM one?! Is anyone on here running a de-cated DP with the CEL eliminator?!
1. The Phuz DP has a racing cat, so you don't get a CEL
2. The Phuz DP costs more than cutting the cat out of your OEM pipe.
3. The Puhz DP is legal, a catless pipe is not
Moderator
Re: (adykes)
1. the CEL can be eliminated using the eliminator
2. That's good - better to de-cat your stock DP
3. No one really notices that - NYS inspection is OBD hookup only - no emissions test
I guess the question is what is the difference in size between Phuz and stock?!
Does anyone have a picture of both side by side?
Re: (tomedkaz)
I will field this one. Just like IPD, ViVA, Eurosport...it is 3" high flow and yields the same performance benefits. I believe the stock is 2.5" (at the most). Feel free to correct me if I'm wrong.
Re: (adykes)
This is probably more or less true, however, a few of us with the Ferrita DP (with Kemira race cat) do get the occasionaly CEL with DTC P0420 (Catalyst system below Efficiency Threshold Bank1).
I have read here on SS and from IPD that this is usually solved with the 'CEL BOS' (IPD/RaliTech). The CEL BOS is a rear O2 sensor extension which takes the sensor out of the direct exhaust flow.
http://forums.swedespeed.com/zerothread?id=94202
I do no not have direct experience with the CEL BOS (yet).
LTA
Moderator
Re: (phuz)
Thank for this info.
So basically, we need to ask Phuz to develop a catless DP for those who don't need a cat.
Phuz, what do you say? If the price can come down by 200 or so - it's well worth it.
Re: (tomedkaz)
Find a market for me, and I'll make it happen. I have no problem with that. Unfortunately, most of us NEED the CAT in there for inspection purposes http://********************/smile/emthdown.gif
1 - 20 of 34 Posts
