Hey,<br>I have a 2003 V70 that was not originally ordered with HomeLink. Is it possible to buy a HomeLink visor and install it? Are there other parts needed for HomeLink to function?<p>Thanks!
Re: Possible to install HomeLink? (66revolver)
A hot lead (wire), it don't run by itself!<br>Not too difficult a job to feed a wire throught the A pillar.<br>However you may want to price out the visor and sit down while you're doing that.<br>(Oh and bend over too) <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: Possible to install HomeLink? (JRL)
Oh yes, it's gotta have power! I was wondering if there might already be a power plug up there as standard. The visor itself is expensive!!! But, I was thinking of getting a used one.<p>If it's only a matter of running power I might take it on! I wasn't sure if the actual transmitter was contained in the visor or if it was just a controller for a transmitter located somewhere else.<p>Thanks!
nope everything is in the visor just need to power it
Re: (Chilled Man)
yep, i just looked it up on myswedishparts.com, in the convenience area. it, the visor, sells for about $255 bucks. some short explanation of the install and programming the remotes can also be found through the site.<p>good luck.
