Discussion Starter #1
Looked at an 1999 s80 T6 yeaterday, the vehicle only goes into gear in manual mode. Transmission is noisy ( sounds like a power steering pump that's low on fluid) Body is perfect, intrior decent. 160k on the car. It is only 1000.00, anyone had this transmission issue and fixed it one their own? Also is there anything else I should check the car for. Only had 850's and s60's before so I'm not sure what all goes bad on these vehicles.
Thanks
dude, pass it by. the S80 is the most expensive model to work on. the tranny swap can run you 5 times the money you are paying for the car alone. the 1999 is the worst model for reliability.
