1 - 8 of 8 Posts
Hi fellow members,
I'm looking for some assistance with some noise I'm getting from my front end. I'm trying to figure out if it's tire tread or bearing related.
I know our cars are hard on tires and I do have some cupping. I've moved the noisy ones to the rear and thought I had left the quiet ones up front. I've booked an appointment with the local tire store to have a look at the tires for tomorrow for cupping and a possible tire belt issue.
Over the past few days I've also noticed that the car is making a lot of travel noise at certain speeds. Around 50-60kph the car sounds like a truck with big nubby tires. I've also notice that when getting on an on-ramp and turning right the car make even more noise, which is why I am thinking possible bearings. It only happens turning right, not left.
Have any of you experienced this kind of noice and/or bearing issues? If so, how easy/hard is it to have the front bearings replaced? I'm really hoping it's not like my Toyota Handlander where I had to buy an entire hub assembly (for $550) to replace a $30 bearing. Can you just buy bearings and replace them without having to buy half a car?
Thanks all for your help.
Front bearings are push-in style and require a press. I have had both fronts done, one under warranty, one not. My sister had one done not under warranty as well. Both of ours cost $350 each (these were done at the dealer, btw).
You are correct, the left wheel bearing is out.
Tires are best checked just by running your hands over them. A belt problem will normally show as a low area running diagonally from one side to the other.
Thanks, nice to know they can be pressed rather than buying a whole front end.
That's what I was thinking as well. Will have it checked.
There is some cupping. Not much, but some. I've noticed a slow speed wobble from the front, which I suspect is a belt issue, which is why she's going into the tire shop tomorrow.
Thanks
Get it aligned after the bearing change. The whole knuckle has to come off to press the bearing out/in.
Good idea. Thanks.
Does anyone have some part numbers for the front bearings?
rockauto is cheapest place found for these.
1 - 8 of 8 Posts
