1 - 20 of 181 Posts
· Registered
Everyone wants/wanted black and you want chrome???
(and no, not easy at all. The only way it would be is for someone to come up with a stick-on kit, like those UGLY Chrysler 300s that some have them stuck on).
How far inside the ghetto do you live?
· Registered
No kidding, I would love to get rid of the chrome window trim on my T6. I wonder if I peel off the chrome trim if it will look like the first pic...?
· Registered
...and right now there is someone in Europe saying " I hate this black window trim and want the chrome trim the yanks have".
· Registered
The "chrome" trim is just plasticky chrome looking junk. I plasti-dipped mine with Smoke to get rid of it, so it looks like brushed aluminum now. It was either that, or go with black.
And as noted, it's not easy to change. It practically involves bodywork.
· Registered
I'll grab one when I clean the car this weekend. I won't lie, though....it was a pain in the buttocks to do. Not hard, just really time consuming.
· Registered
Did the dip peel around the trim naturally?
As you may recall I have done a lot of dipping, and I know exactly how smoke dip looks over chrome, but I have hesitated trying to dip the chrome window surround due to it not appearing to have much of a gap to create an edge for the dip...
· Registered
Here you go...not the easiest thing to capture in photos (and ignore the CVS sign reflected in the windows. As noted, it is a pain in the rump and takes a lot of time to peel the residue off. Some areas required a little "help" with a blade to get the edge you need to peel. 4 coats, btw
· Registered
That is four coats of smoke? Must be very thin coats... barely looks dark at all... :) No wonder you found it hard to clean up/peel, that's just too thin. If you don't want it darker than this I would say do four layers of smoke, and then another four of clear plastidip, you will find it much easier to peel/cleanup and also more durable over time. I would want a darker look so I'll probably just do 8+ coats of smoke. How many cans did you need to do four coats?
· Registered
While I thank the resident expert for chiming in, I'll repeat myself on a few points and clarify a few others.
It doesn't photograph well, period. You have to see it in person.
It wasn't difficult to peel because of the "light coats", which they weren't. It was a pain because of how much surface area you had to peel off AND the rubber window trim gaskets not releasing the dip as easily as glass or paint would.
It was also a pain because of the large masking area and large spray area (you want to do all the trim on one side of the car at the same time).
It took a long time due to that large area and wait time between coats.
I didn't want clear on it, and didn't want to do 8 coats of dip. period. That would've taken too long and I got the results I desired. I didn't want it "dark", I wanted it "less chromed", like my tailgate badges. It gives it a brushed aluminum look, which is what I wanted.
Again, it cannot be captured in photos.
Sorry for the rant, but I've been dipping a lot of stuff lately, and I think I've got the process down pretty well.
· Registered
Thanks for the added detail - did not sound rant-like to me at all. :)
How long are you waiting between coats? How many cans did you use total?
· Registered
20 minutes between coats, went into a 3rd can between both sides (didn't want to dredge up the bottom of the 2nd can as the last coat on the passenger side).
Keep in mind, that trim is actually plastic and has a very strange finish to it.
I am waiting on my R-design mirror covers to in today, and was hoping to do the same thing. But I think the finish on those is different than the window trim. At least dip is easy to remove if you don't like it.
· Registered
OK, I will probably try this and use 3-4 cans sometime in the next few months, once the weather is warm and I have a few hours of spare time...
· Registered
This is really funny... I have black aluminum trim on my '10 V70 RD and I would prefer chrome or brushed aluminum. The black aluminum gets some discoloration from the sun (?) and weathering I guess, almost looks like oil stains (it's not). But they should have chosen brushed aluminum trim to match the roof rails, mirror caps, and grille trim... Ah well. The smoked chrome trim looks really good though that T5 for Life did, that would match the trim on my car really well, but no way I'm going through that Phuck-It-Up-Myself project....
· Registered
It's not hard, just really time consuming. Good thing is, it's totally reversible...just peel it off if you don't like it!
I've often wondered why they have 400 different types of "metal-looking" trim on these cars, particularly the XC70. The window trim is different than the fog light/rear reflector trim, which is different from the lower front lip and rear bumper pieces, which is different from the front grille. If it was all the same, it would be easier to customize, imho.
· Registered
10 years later: anybody has a partnumber for the BLACK TRIM? Wanna get rid of the Chrome around the windows all of a sudden...Tony's fault. Im ready to dip the plastidip hell out of my car. Starting to hate chrome... Im in a bad mood!!
(XC70 D5 AWD GT Polestar IPD Sway)
1 - 20 of 181 Posts
