1 - 20 of 30 Posts
Hey Guy´s!
I have an C30 T5 MY08 and I would like an Pop-Off, Blow-Off in it!!
Can anyone help me, What Pop-, Blow-Off i should take?!? I would only have the Sound! Not Performance or something... I habe BSR Stage 2
Also it goes only about the Sound!
But when me can give anyone a Tipp... I dont search only an Pop-, Blow-Off... I would only to hear the Turbo better! That´s the only one i like!
Sorry for my bad English but iam from Germany and my Englisch are a little inexpertly...
Also I where thankful to some can help me or give me an Tip.
Thanks ahead!
grEEz
apoLLoT5
Re: (chromecarz00)
Really! If you are considering a blow off valve, you should even hesitate at the idea of an intake and or removing the sound deadening.
My understanding that a blow off valve is useless on the C30. Unless you are looking to enhance the sound of the turbo, it's not going to make much of a difference.
The T5 uses a compressor bypass valve instead of a blowoff valve, so the air goes into the intake.
You can replace it with a blowoff valve, but since the bypass valve is after the airflow sensor, it will cause the engine to run rich.
This will eventually lead to a failure of the catalytic converter.
Modified by Shomare at 9:21 PM 4-19-2009
Re: (shagginwagon)
Quote, originally posted by shagginwagon »
you will hear the turbo working a lot more with an open intake. also take off the sound insulation mat under the hood.
+1 for the Open intake (K&N Typhoon is good).
+1 for taking off the blanket. It makes a huge difference!!!
I agree with the rest of the folks here. With you already running BSR Stage II and contemplating a BOV, installing an intake and removing the blanket is nothing you should even hesitate about.
Hmm... Ok!
Then i remove the blanket und test the sound...!
But what are you mean whit the intake??! What I should chance??? Can any one send me per PN info´s?!? Or can anyone tell me in German??! My English are not really good...
Re: (apoLLoT5^)
Although i havent gotten around to doing it yet heres some info that i verified with IPD and from my own research have determined BOV's are more than fine for our setups minus the misconception from most swedespeed members.
http://forums.swedespeed.com/zerothread?id=116197
Re: (apoLLoT5^)
I think they were refering to removing the blanket after installing the aftermarket intake. The stock air box cuts down a lot of turbo noise.
Re: (ForceFed Motorsports)
So I removed my hood blanket tonight, testing the sound before and after. To be completely honest it doesn't sound that much different, if at all. It is super easy to take off and put back on, so it won't hurt for anyone wanting to do it to try it out and see. I will probably just put mine back on.
LOL. I don't know. My car is beastly sounding when I rev it, but it didn't sound any more beastly with the blanket off...
Re: (carreragt7)
Quote, originally posted by carreragt7 »
It affected my non-deep notes, never really cared for those too...
if that makes any sense
Discussion Starter · #19 ·
Yeah, ForceFed!
Its only an Panel Filter, it makes some different to Original but only at acceleration. But nothing on Sound...
Sound have chanced only to put on my 3" Exhaust Sport System with 200 Cell Racing KAT... But I don´t hear the turbo better...
Also the typical, Tzzzzscccchhhhh Tzzzzsccccchhhhhh Sound i can´t can get...
Sorry for my Bad English...
German we can talk to!
Then I Understand evtl. some better.
Re: (apoLLoT5^)
You would hear the turbo much better with a open filter like the BSR or K&N kits that replace the factory air box. If your just lookin for more sound from the turbo id look into either of those.
1 - 20 of 30 Posts
