1 - 20 of 80 Posts
Anyone have any ideas or suggestions for better mileage improvements. It seems like I'm getting very poor gas mileage (I estimate around 22-24 mpg highway). I have the K&N panel but have not installed since I heard someone here said the oil can damage the MAF sensor. How about that Tornado gadget? Does that thing really work? Will replacing the fuel filter help any? The manual says replace at 105K miles but my car only has 63K miles.
Re: Poor gas mileage (blackTT55)
That is low -- I usually see 28 -31 depending on speed, etc.
Increase your tire pressure and remove any unnecessary weight for an easy boost.
Mpg is affected by speed. What highway speed do you average?
I average about 25mpg at 75mpg highway in a stock 98 S70T5 manual w/ synthetic, but in a related post, JRL reported averaging 30mpg at 60-65, with the same model. I am going to at least try to slow down on my next road trip & see what effect it has on my overall mpg.
Here in So. Cal, as you know, gas is knocking at $4.00's door ($3.29 -$3.79...depending on the grade).
Mpg didn't matter to me when gas was in the $2 range, but now it has my attention.
Good luck on improving yours!
Re: (Taleof2Bricks2)
Quote, originally posted by Taleof2Bricks2 »
Mpg is affected by speed. What highway speed do you average? I average about 25mpg at 75mpg highway in a stock 98 S70T5 manual w/ synthetic, but in a related post, JRL reported averaging 30mpg at 60-65, with the same model. I am going to at least try to slow down on my next road trip & see what effect it has on my overall mpg.
Here in So. Cal, as you know, gas is knocking at $4.00's door ($3.29 -$3.79...depending on the grade). Mpg didn't matter to me when gas was in the $2 range, but now it has my attention. Good luck on improving yours!
$3.49 for 92 octane here. Use cruise control (boring, I know), roll up your windows and don't use your AC...
Re: (darylkaiser30)
Quote, originally posted by darylkaiser30 »
I have to admit that I avg 75+mph most of the time (that's only when the fwy are cleared.
Using cruise control is almost impossible in southern cali with all the congested traffic. I'm running on mobil 1 synthetic now with 91 octane ($3.64 per gallon). I might replace the spark plugs to see if it helps.
a well tuned machine helps....even the often overlooked things such as tire pressure can make a difference....amen on the cruise control here in Cali, just no use for this gadget...
TIRE PRESSURE! Drive with a light foot, I can get 28 or 29 but often get 24 or 25... why? my own fault.
tornado is BS
Re: (Maynard)
Quote, originally posted by Maynard »
I have a K&N drop in filter, admittedly I do use cruise control a lot on the highway averaging right around 75mph, but I usually get around 31mpg.
I can coax +40mpg out of mine if I am careful. I admittedly don't use the CC much either, but it is the easiest way to regulate mpg and this is how the manufacturer estimates their own mpg. The turbo is just way too much fun though!
Re: (blackTT55)
Quote, originally posted by blackTT55 »
Yikes. 92 octane in MN is still within a few pennies of $3/gal - just under right now I think... still cheap enough that I don't care about my MPG. FWIW, I've seen 30-32MPG doing 60MPH and also 22MPG doing about 80 or so in a headwind. It's not uncommon for me to touch 100+MPH on open stretches, these cars just love speed!
I average 30-35 mpg highway at ~70-75 mph, so you are definitely on the low side. As for the K&N, IMO it is safe as long as you don't over-oil the filter.
DO NOT BUY THE TORNADO, it is a scam and you already have a turbo so why would you want some "AS SEEN ON TV" product in your finely tuned automobile??? IT DOES NOT WORK!!!
I agree with adjusting the tire pressure, it may help a little bit, but not 10 mpg. With 63,000, not sure what your issue is.
22-24 is not VERY poor, probably around average.
Are you a 5 speed or automatic?
For automatics that is about right, a 5 speed should get 28+ at 65 mph, level ground and a light foot.
Your mileage will drop dramatically if you give it even the smallest amount of fuel
40mpg reported above by darylkaiser... is pretty darn good! Corolla mileage with Volvo power & comfort!
I left my lead foot home last Saturday & on a 60 mile round trip highway run, I averaged 30mpg, with a 98t5 well maintained manual, slowing down to 65 from my avg 75mph or more, where I only averaged 24-24.
I hear a lot about weight & am not sure how much a pound here or there affects speed, but taking my 2 sons w/ a combined weight of 250 lbs for a similar run on Sunday, I dropped back to 24 mpg....
Probably safe to say your passengers/load can affect mpg also.
Interesting input from all on this topic!
Discussion Starter · #16 ·
Re: Poor gas mileage (Cornfed)
Quote, originally posted by Cornfed »
WTF, I don't think this is possible. Does anyone else get these kind of numbers as cornfed is claiming?
That's bull and easy if your foot's off the gas
. One light touch on the gas and it will drop immediately to 20.
You STILL didn't say whether your car's a 5 speed or an auto
getting over 30 on these cars is total BS... anyone that says otherwise is a liar
Re: (Bender)
Quote, originally posted by Bender »
I don't take kindly to being called a liar. However, what I said earlier about averaging 31mph on highway trips is a completely truthful statement.
Discussion Starter · #20 ·
Re: (Maynard)
Are you referring to your 01 S60 NA? If so it may be possible but I thought we're talking about an S60 T5, btw, it's an automatic with manual geartronics. I think at best you may be able to acheive 27-28 mpg on the T5s but mines is getting about 24 at best.
1 - 20 of 80 Posts
