1 - 16 of 16 Posts
Hey,
So I was just browsing, and saw that Viva sells the 20" Polestar wheels. They're expensive obviously, and it's just kind of a dream, but would I EVER be able to put these on my 04 VR? If so what would the tire size have to be?..
Thanks,
Spence
Sent from my SAMSUNG-SM-G900A using Tapatalk
Moderator
The bolt pattern is not what our caRs take
Really? Wow that's a shame. So how about spacers. I could get those correct?
Maybe but probably not? You're in uncharted territory I think. Probably better off to just find some good wheels that look similar that are known to fit.
Administrator
The bolt pattern is the same it is the center bore (63.4mm) that is different (smaller). A hub adapter is what you need.
I was running S60/V60 wheels on my V70R. I picked up a spacer with an integrated hub adapter from ViVA Performance:
Seen them on a 960 .sure ive seen pegasus wheels on a 960 , not sure sure they would due to outer dia .
You can also bore out the new wheels if you have a decent machine shop.
Personal taste, but I don't really like the look of that 960. Those wheels are way too big for the tiny brakes and stock height.
Moderator
An alternative that fits and looks similar (but needs hubcentric rings) are Fast Wheels FC04's. Im picking up a set this month
Cool post some pics when you get em up!
These BBS are also in the same style "family" and look really good on an R:
(image shamelessly stolen from Quin)
2004 S60R 6M - 2006 V70R 6M - 2014 XC60 R-Design OSD - 2015.5 XC70 T6 Platinum
Is the center cap hole the same size as a factory Volvo center cap?
Yes, the BBS SR comes in 5x108.
Hey,
Thanks,
Spence
Just checked out viva site and didnt see polestar rims.
Just do a search for polestar. $700 each, caps not included
Part # for the P* 19" is 31408850, 20" is 31408095. They both work at most on-line web stores like Tasca. They come in $430-$450 depending where you look. I don't have the part# for the grey center caps, but the regular Volvo ones work. The dealer where I bought my P* had 20" on a S60RD with regular center caps installed.
1 - 16 of 16 Posts
