Quote, originally posted by kitkat » |
I found a screw on the inside aspect of my left rear tire, it was on the shoulder, I took it out and plugged it myself. Any thought on the stupidity or shear genius of doing that. I figure Ill never rotate that tire to the front. |
Quote, originally posted by ss60 » |
In the contact area - liveable and should last. On the shoulders or sidewall, throw the tire away - It'll eventually blow. |
it was right in the tread right wear the tread flattens to the side, at an angle. |
Quote, originally posted by petew » |
never repair a tire on a performance car no exceptions perfectly fine for all you Camry drivers. ![]() |
Quote, originally posted by Needsdecaf » |
Pete, usually I let you rant but this time you are not correct. Michelin and Pirelli both have programs to train techs to repair tires that are Z, W and Y rated (not in sidewall of course) and for the tire to retain that rating. Europeans are very not into throwing things away. ![]() |
Quote, originally posted by JRL » |
Agreed. A tire should not be repaired unless the hole is in the tread area |
never repair a tire on a performance car no exceptions |
