Hello,
I am replacing the radiator on a 2002 Volvo S60 2.4t. Please let me know of where to connect the rectangular plug. I know the cylindrical plug goes to the fan, but I cannot recall the placement of the rectangular plug.
Both plugs are part of the MAF harness, if you need a reference point.
Thanks for the support
Is one of them to the purge solenoid mounted on the right side of the radiator? (If you are looking at it from the front). The purge solenoid mounts to the fan shroud assembly
Edit: Scratch that. Read your post wrong. Missed the rectangular part lol
Sent from my m8 using Tapatalk
To me it looks like the pressure sensor connector for a/c mounted on the condenser on the passenger side...but you said its on the Maf harness...
The only items on the drivers side is the evap valve, pressure sensor on the intercooler and piping, and brake vacuum pump sensor which is a two pin, not 3...
