Hi,<p>Have a nice suspension clunk in my '02 V70 T5 5sp going that I just can't pin down.<p>I hear it and feel it coming from under my left foot. It does not occur consistently - sometimes it happens when I shift, sometimes not. On occasion it clunks over rough pavement - or not.<p>I don't *think* it is the axle spline issue, which I had repaired about a year ago. That sound I could re-create just by jabbing the accelerator in first or second. It is also not the top engine mount - had that replaced.<p>Finally, I had hoped replacing the sway bar end links with the ipd HD hardware would do the trick, but no love.<p>TIA,<p>Harry J
Re: Please help diagnose a suspension clunk (harryj)
Cracked strut mount, broken spring seat, control arm bushing. Probably one of those<br>You neglected to say how many miles<br>You should not have had any axle issue with an 02
Re: Please help diagnose a suspension clunk (JRL)
Sorry - 45k miles on the odo.<p>Any other suggestions?<p>Thanks,<p>Harry J<BR><BR>
<i>Modified by harryj at 12:01 PM 6-14-2006</i>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote"> control arm bushing. Probably one of those<br></TD></TR></TABLE><br>Most likely the culprit. Although his mileage is kinda low for that but it is a "weak" link (the rear sway bar links more common).<p>I just replaced both my control arm bushings, at 74,500 miles; thank God for warranty!<p>Yannis
Re: Please help diagnose a suspension clunk (GrecianVolvo)
Thanks, Yannis - I'll probably have an independent shop do the work. Roughly how much should the repair cost?<p>Best,<p>Harry J
As I recall, at my indie it was around $135. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/cool.gif" BORDER="0">
Re: Please help diagnose a suspension clunk (Steely)
<I>I just replaced both my control arm bushings, at 74,500 miles; thank God for warranty!<p>Yannis<p></I> <p><br>My 01 T5 made it to around 88k.... Not bad for the kind of driving we do around here. <p><I>As I recall, at my indie it was around $135. </I><p>I'll bet that was for one side and for either a front or back side bushing. There are 2 per front wheel. To do it [email protected] $400 at an indie....maybe $500 at a dealership.<br>BTW....a good idea to check those tie rods when you are done with the bushings, but before the assembly is remounted....no sense paying labor for the teardown.
