1 - 18 of 18 Posts
What do you think?
Bent/crack fixed.
Re-Adjusted Rear Coils to lowest setting
Rim Cut out template. now taping is just a snap away.
The lowest setting i can go eliminate vibrations :) Rear is 90% and front is 80% lowest settings.
I like it very much! glad to see everything getting back into place :D
I did not mind the yellow but the red will give you an easier time. I might consider doing this too . . .
Wow that fix is a real patch! I hope it will hold well! I'm guessing the wheels where off balanced after that. Nothing that can't be adjusted as you balanced the tires...
Diggin' 'em, but good luck keeping it clean without ripping the plasti-dip! Sharp wheels!
That looks IMO very very cool - Not overtly in your face, but a nice pop of color to give it a custom, no one else has this, kind of look.
Check plus.
LOOKS GREAT! go 100% low!!!
im just jelly cause i only have springs. want coilovers badly. need lower.
I had originally the yellows for 2 months, power wash, brush wheels and i have lots of room to clear my arms inside. plasti dip stayed on. easy to clean than i originaly thought. Tip: after 5 coats or plastidip, remove tape immediately before it gets dry, this is to avoid pulling the tape when dry can cause rubber in the edge to bend. you only need 3 cans for 4 wheels is enough coating that will stand out. i remove my yellow in 2 sec in 1 pce. without removing the wheels from the car.
yes, not too noticable in centain angles, but when you really look, it looks great (to me at least) :)
That weld looks like it needs a counter balance on the other side...haha.
Looks good but could be a pain trying to keep the red clean.
The weld is perfect, in fact, the wheel itself (no tires) is 100% balanced and round before the shop release them. I saw them myself. When i installed new tires, the rims need less wheights. i was surprised about the work they did with the wheels before and after. :)
It just looks nasty, but technically the wheels only are prefectly balanced.
wow after dropping your rear some more, the tire looks so much more flush and under your fender, unlike how it was before, Awesome job man. i love those rims. glad everyone worked out and got fixed! Beautiful man. :thumbup:
I really dig it! Keep us posted with pics after time on the road and the cleaning schedule. I can see myself 'borrowing' this idea!
Discussion Starter · #14 ·
been riding them everyday for more then 2 months now with once a week car wash. looks awsome. the plasti dip really stick up. i do brush them once a week.
the trick is, do just about 4 - 5 coats, while still wet, remove the tape.
i had my yellows on originally for testing. have not cleanned them for a month and i see a lot of brake dust, just brush normally. i find them eash to clean becasue of the clearnace of thre vanillas my hand fits going inside.
next season fall, i will get my rims a nice good wash and fix the rashes and may permanently color them red with clear top coat.
So I've been skipping over this thread for a while now because the pictures wouldn't show up at work... glad I finally got a look, because oh mah god... I really would like to find a way to do this in a deep purple.
Nicely done! Im also going to work with some plastidip in the next few weeks :)
I dont think its smart to use plastidip on brakes? Because of temperature?
plstidip looses elasticity when its too warm.
i would def not use that on brakes.
Sent from my GT-I9100M using Tapatalk 2
1 - 18 of 18 Posts
