1 - 19 of 19 Posts
Discussion Starter #1
Do i need to remove the engine to throw in a new piston, one is melted, dont know what to do about it? on a 99 xc.
Technically it can be done in car, with the oil pan and the cylinder head off. How do you know it's melted?
Discussion Starter #3
Piston #2
It can be done, but if that piston did more damage to the walls than a light glaze braking hone can provide, your just throwing good money to bad as you won't be pleased with the outcome or longevity of your efforts.
Yeah, that cylinder wall looks like there was a chunk taken out. No hone could get rid of that without seriously opening up the diameter of that cylinder.
Told youuuuuu... Now are you ready to go to the junkyard? They have a 98 sitting on the lot right nowwwwwww!
Discussion Starter #8
That 98 wont work because of ignition system. but i found a 99 in suffolk. I just have no idea how to do a swap or the tools needed(BTW I want that perfo you have)
im pretty sure 98 and 99 blocks are interchagneable. So all youd have to do is swap heads. Unless you wanted to get a complete motor and not mess with swapping everything over
My bad, I thought you had a 98... Why dont you just sell me this wagon? :)
Discussion Starter #13
Do you want this wagon? I dont have time for it. Itl be a great car after its engine is worked out.
Discussion Starter #14
Whats the head swap like? I have someone needing a head for their 98 2.4L is the distributor/vvt swap possible/easy?
We dont mean swap your car from coil ignition to distributor.
We mean buy junkyard motor then tear it down to the block. Then you strip the parts off your blown up motor (head, oil pan, accesories, etc) and transfer those parts to the junkyard block.
Discussion Starter #16
i understand that, i found a whole new motor though. but NJGreenBuild needs a new head for his 98
so grab the motor at your local junkyard and take the block for yourself and ship him the head. Thats prob your best bet at this point
I wasn't looking at it for an upgrade but rather to get the car driveable period. Anyways I'm gonna be okay, I have decided to just swap in an entire spare '02 RN motor rather than continue to fuss with this current engine. Thanks very much though and good luck with your new motor too!
1 - 19 of 19 Posts
