Piston + Rod + Stroke using a 4T9 Block?
4.2K views 9 replies 4 participants last post by  BrotherMatt
The pin height for the Wiseco 2.4T5 piston is 30.38mm
P/N is ASC-007789 and it’s not custom. You will need a .25mm bore clean-up.
Can can also buy OE Volvo 2.4T5 pistons that come with the best rings.
Is there an advantage to using OEM rings vs. Wiseco?
