<A HREF="http://www.powerbulbs.com" TARGET="_blank">http://www.powerbulbs.com</A>/ Click the link and go to Silver Vision<p>looks pretty neat.. basically just style... but its not just a tint/gel cap over the stock bulb. which is better i guess.<p>but thats pretty expensive... 43 Bucks US<p><BR><BR>
[Modified by GShyneDM, 3:52 PM 1-20-2003]
Re: Philips Silver Vision.... (GShyneDM)
Pfft.. What a waste. Do it yourself. Buy some regular bulbs and then spray a thin coat of silver paint over it. It does exactly the same thing. Eitherway, you loose a little light due to the coating.
Re: Philips Silver Vision.... (mike_c70)
<BLOCKQUOTE>quote:<HR>Pfft.. What a waste. Do it yourself. Buy some regular bulbs and then spray a thin coat of silver paint over it. It does exactly the same thing. Eitherway, you loose a little light due to the coating.<HR></BLOCKQUOTE><p>actual paint.. probably not.. or well not as efficiently.. because the paint is pretty thick if you put just enough to cover the yellowness. You'll barely even see the light.<p>perhaps some think silver see thru foil or sumthing. but the tint would definitely loose that yellowness, i would think.<p>might as well get a blue ricer bulb <IMG NAME="icon" SRC="http://********************/smile/emsmilep.gif" BORDER="0"> ahhahah <p>the only thing that i find good is that although it is silver coated, it still blinks yellow. unlike the cheaper Ricer kind that blink white/blue/red/etc... isnt Yellow US regulations or sumthing? or is it as unimportant as that yellow reflector on the side of our cars <IMG NAME="icon" SRC="http://********************/smile/emsmilep.gif" BORDER="0"><BR><BR>
[Modified by GShyneDM, 5:15 PM 1-20-2003]
I had a buddy with a Scooby use model airplane paint, special silver mirror relective paint for cockpits or windows. It looked just like those, but it did make his blinkers a little dimmer.
Yes, actual paint. Just spray very thin coats at a time. I'm pretty sure that those Philips ones aren't as bright as the stock yellow light.
But the Razo gigalux ones are. Premium white zero or the regular PW ones are very good for what they cost.
Re: Philips Silver Vision.... (The_one_n_only)
My friend has a Yukon, with cleared corners, and he was bothered by the reflection so he used heat-shrink on the back of the bulbs and it cleaned up the yellow mess pretty well.
