1 - 20 of 47 Posts
Hey guys,
My ‘07 S60 just doesn’t do well in repeated braking in the hills.
I’ve got the basic 286mm setup. Doesn’t take much for them to overheat, and for the pedal to go soft. We’ve got easy cheap upgrades to bigger OEM brakes, maybe at least go up to 305mm.. but I want to see if I can do basics first.
Maintenance wise, the car is in good shape. Brake fluid is clear and less than a couple years old, lines are good, rotors are less than a year old.. but I also installed pads from Max Brakes last year, and they overheat *way* before the factory pads they replaced. Like, one hard thirty second run on a tight technical downhill, and they seriously degrade. They were cheap, and you get what you pay for, so I’m gonna try replacing those first.
Brake dust isn’t a huge concern, squeaky brakes don’t bother me, but it is primarily a street car, so track pads are a bit much.
What are you guys running? Any and all input and experience appreciated.
Hey guys,
I have always been a big fan of Hawk 5.0 and a bigger fan of Porterfield R4S pads. I can special order the R4S pads and give you a SS discount to help you out! Shoot me a PM.
Go 305mm or 316mm from XC90 if you have 17” wheels.
I’m in process of switching over to Powerstop pads and rotors. They are pretty pedestrian but should be similar to stock feel while having carbon ceramic compound and new SS brake lines. Maybe increased pedal feel?
If you’re running new stock rotors, I’d change out the pads ASAP with minimal cost. They shouldn’t be running that hot unless you’re riding them the whole way down the hill. If that’s the case, a quick refresher on appropriate braking techniques should keep them cooler.
Discussion Starter · #5 · (Edited)
18”, so I’ve got room. Do the 316mm rotors just require the larger bracket/carrier for the calipers I have?
I’m definitely not riding the brakes, using engine braking where possible. This car is automatic but I still select a lower gear to try and help the brakes a bit. These are roads I’ve driven multiple times with many different cars, and I’ve never had brake fade like this - and more to the point, they weren’t this bad on the original pads. I thought it was possible they were dragging, which would explain why they’re so quick to overheat, but that doesn’t seem to be the issue.
That makes sense. Likely just the pad compound then. Any excessive dust?Maybe just swap the fronts to see if you get different results before swapping the rears?
That’s a quick fix and could clear up the heat issues. I’d keep the rotors unless you see some heat glazing on them. If so, getting them surfaced when you add new pads could be the difference.
The problem is the stock brakes just suck. They suck on the XC70 and V70 just as much. They’re tiny for what the car weighs and while functional, confidence inspiring they are not.
XC90 316mm require an entirely new caliper/carrier/line/pad/rotor as well as enlarging the spindle holes to 14mm.
I have them on my 03 and it’s not wanting for any braking power. Zimmerman rotors, new pagid pads and a fresh flush.
I've seen you mention XC90 hoses a few times, I'm curious as to why they are required? Quite a few including myself have used the existing hoses without issues. I do believe that it's a good idea to replace old hoses while you're at it, but I don't think XC90 hoses are required.
Not sure I said XC90 hoses specifically but just new hoses. The actual pn is 30778919. Fitment is all p2 with 316/320mm brake kits.
How long since fluid flush?
FCPeuro has SS lines for less than $50 for a full set!!
That said, on previous cars I've had great success and results with Stop-Tech 309 series pads. They will hold up fade free during auto-X but are street friendly as well. Comparable to Hawk HPS pads, but better in my opinion. Connor above has a good recommendation on the Porterfield R4S pads as well.
Sent from my Huawei Mate 9 using Tapatalk
Slotted rotors will also help sweep out gasses and help dissipate some heat.
Discussion Starter · #14 ·
Only a year or so, but just standard issue. I have thought about replacing it with something with a higher boiling point.
Agreed. I had a 2005 A4 Quattro 2.0T and the front brakes were 312mm stock. A simple pad upgrade made them perfect on the same roads that are causing the Volvo problems. It’s not magic, I may need to accept that and upgrade.
And while I’m at it...
I think I went too far in that direction...
I went with slotted AND drilled rotors, which are better in theory for heat dissipation... but if the rotors are too small to begin with, I’ve taken away rotor surface, and probably made things worse.
I’ll look into all the pads mentioned here, give that a shot.. but if it doesn’t work, I’ll have to admit defeat and upgrade the whole setup.
If the two surfaces were flat( pad and rotor) there would actually be less usable surface due to the gasses pushing back against the pads. Its the reason the pads have slots as well.
Discussion Starter · #16 ·
Understood and agreed. The benefit isn’t in dispute, but there is a law of diminishing returns that could be at work here.
By going with drilled and slotted rotors, I’ve got the best possible setup for letting gas escape - but I’ve also reduced total swept brake area. The usual way to solve that issue is.. getting bigger rotors. If I’ve already got small rotors, and I take away TOO much swept area, that could be why the brakes are getting so hot. There’s a trial and error going on here, I’m trying to find that proper balance.
If it’s simply a bad pad compound, performance pads will solve that, so I’ll try that first. If they still overheat, then increasing the size of the rotor (while probably staying slotted and/or drilled) is the next step I probably take.
Could be pad compound, i use ceramic, more dust but better stopping power. The more aggressive the pad compound the faster the rotors wear. ie. race pads. I noticed a lot less issues with iPd lines and premium fluid flush as well. Either way you go, make sure you bed them properly.
I kept the OEM size of 316mm from my car but upgraded all the remaining parts. Went with Tarox F2000 rotors, Carbotech XP12 in the front and XP10 in the rear, IPD brake lines and Castrol SRF racing brake fluid. The pads are noisy, but have a great bite when cold and when hot they are really really good. The XP12 have a friction coefficient of 0.65 and can take up to 1,000 celsius. I couldn't be happier with this setup.
I went a different way, but am happy with the results. I have the 305 rotors, so results may be different, but I learned that pretty much all rotor blanks come from China, and I trust Chinese steel about as much as I trust Chinese dog treats and baby formula.
So my rationalization is that if they all come from China, I should at least try to minimize my exposure, so I went with Centric High Carbon alloy rotors. They aren't available on the rears, and not sure if they can be found for 286mm fronts, which kinda sucks. I also have been very happy with their Posi-Quiet ceramic pads. I've put them on multiple cars and they bite well, and emit much less brake dust than semi-metallic.
Made a couple trips from AZ to San Diego over the Santa Anas fully loaded and they did not heat up or fade. No probs in CA traffic or dealing with left-lane-lame-o's either.
Still on them a good 50k later, too.
I'm an Uber driver and my XC60 has stock size brakes, but I went with slotted and drilled rotors with akebono ceramic pads in front. Installed at 117,000 miles and I currently have 183,000. I checked my brakes the other day and the pad is still thicker than the width of my index finger. I'll likely get 100,000+ miles out of this setup. Will do the same for the rear when the time comes!
1 - 20 of 47 Posts
