1 - 15 of 15 Posts
Discussion Starter #1
I searched, couldn't find this anywhere.<p>Is there a 17x7.5 Pegasus wheel, or only 17x8?<br>What is the weight of these or this wheel?<p>I'm assuming they / it are 46 mm offset as has been written in other places. Does that mean Volvo V70, which I've read has 49 mm offset, allows for changing to 46 mm offset with a wheel upgrade? Or is the R version a different geometry, with a different suspension somehow?<p>(in other words, does Volvo in one case recommend a change of wheel offset for their car from one number (49) to a DIFFERENT number (46)???)<p>(posting on this forum because it relates to whether I consider using a Pegasus wheel for V50). <p>Thanks.<br>
All the Volvo Pegasus wheels (17", 18") are 8" wide. The wheels weights are ~25lbs and ~28lbs for 17" and 18", respectively.<p>In your example, a standard V70 shouldn't have any major issues running Pegasus wheels - just make sure to retain the same overall diameter. With the S40/V50 models, you will need hubcentric rings to use the Pegasus wheels. I hope this helps!<br>
Re: (George @ ViVA)
where can i find hub centric rings for the s40?q
Discussion Starter #4
Re: (mJrO)
Totally helpful, perfect, thanks. Do you or someone know the wheel offset of Pegasus (verify it's 46) and the wheel offset and weights of <p>Amalthea<br>Otrera<br>Sentinel<br>Tethys<br>Thor<p>These all seem to be S60 17x7.5 wheels that could fit on S40/V50 with hubcentric rings (perhaps with steering limiters if needed with AWD).<br>The 8 inches on the Pegasus might be a bit wide for 46 mm offset. Of course the 225 width tire remains the same whether it's 7.5 or 8 inches of wheel. I'm not sure how the fitment issue changes with 17x7.5 versus 17x8 with the same 225 mm tire. (I want 225/45 to stay with the same overall diameter)<p>The Evolve R5 wheel looks the best IMO with Pegasus second best (I like the sporty 5 spoke thing), and weighs the least. Its offset is a bit scarey, though, at 42 mm, although NYCS40 has had no problems with th R5. And tirerack has alternative wheels for V50 even down to 40 mm offset.<p><br>Bassman<p>
Re: (bassman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>bassman</b> »</i></TD></TR><TR><TD CLASS="quote">Do you or someone know ...the wheel offset and weights of <p>Amalthea<br>Otrera<br>Sentinel<br>Tethys<br>Thor<br></TD></TR></TABLE><p>Amalthea - 49mm; 9.9kg<br>Otrera - offset: 43mm; 10.1kg<br>Sentin<B>a</B>l - 49mm; 10.3kg<br>Tethys - 49mm; 9.9kg<br>Thor - offset: 49mm; 9.9kg<p>HTH<br>UKMatt
Discussion Starter #6
Re: (ukmatt)
Pretty whacky that Otrera is 43 mm while the rest are 49. Are you sure that's right?<p>If 43 is real, that would mean, incidentally, that Volvo "okays" a change in scrub radius of 6 mm for the S60 / V70.<p>9.9 kg is a healthy, reasonable 22 pounds, which is what I remember Sculptor to be. Of course a wider tire means a heavier tire. I'm surprised the Pegasus wheel, which is supposed to be the sporty thing, is actually heavier than these other wheels.<p>On the issue of 8 versus 7.5 inches, a wheel/tire calculator such as <br><A HREF="http://gs.tolan-hoechst.com/tirecalc.htm" TARGET="_blank">http://gs.tolan-hoechst.com/tirecalc.htm</A><br>shows that the wheel is WIDER than the tire if I go with 225 mm! Does anyone know if 17x8 is too much for 225 mm? I think Tirerack had something that says 17x7.5 was best suited for 225, but 18x7.5 was best suited for 215. So that doesn't tell me about 17x8 with 225. (I couldn't find the tirerack exact webpage before writing this).<p><br>
Re: (bassman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>bassman</b> »</i></TD></TR><TR><TD CLASS="quote">Pretty whacky that Otrera is 43 mm while the rest are 49. Are you sure that's right?<br></TD></TR></TABLE><p>I am not sure (as in I don't have an Otrera wheel next to me in the hotel room <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">) but that's the information I have... can't confirm to be honest.<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>bassman</b> »</i></TD></TR><TR><TD CLASS="quote"><br>On the issue of 8 versus 7.5 inches, a wheel/tire calculator such as <br><A HREF="http://gs.tolan-hoechst.com/tirecalc.htm" TARGET="_blank">http://gs.tolan-hoechst.com/tirecalc.htm</A><br>shows that the wheel is WIDER than the tire if I go with 225 mm! </TD></TR></TABLE><p>How can that be? a 225 tire is 8.86 inches wide and an 8 inch wheel is, um, 8 inches... <p>UKMatt
Re: (bassman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>bassman</b> »</i></TD></TR><TR><TD CLASS="quote">I'm surprised the Pegasus wheel, which is supposed to be the sporty thing, is actually heavier than these other wheels.</TD></TR></TABLE><br>The Peg is made for the R which has 300hp and is made to corner hard. You think Volvo would underengineer it? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <p>On the subject of rim vs tire widths, have found that TireRack's recommended sizes are spot-on. Their "acceptable" (or whatever second-tier rank) all look funny, either pinched or fat. I personally avoid them, which is what I think TR is trying to tell us.<p>Tom.
Discussion Starter #9
Re: (tmtalpey)
Hi. I just looked at the S60 technical specs on the normal Volvo website. The wheels they offer in 17x7.5 are not the same as I found on autowebaccessories.com. The Volvo recent S60 17x7.5 wheels are<p>Thor<br>Orestes<br>Orpheus<p>then the 17x8 Pegasus (there are other 18 and 16 inch wheels).<p>No mention of half the ones I have in the list from autowebaccessories.com.<p>Since Thor is 49 mm, I'm guessing Orestes and Orpheus are all 49 mm offset.<p>I assume the 17x8 Pegasus is 46 mm, just like the 18x8 Pegasus.<p>So so far it seems that Volvo does NOT recommend a 6 mm offset shift.<br>The S60R has 46 mm Pegasus wheel. So either they do recommend a 3 mm offset shift, or else the S60 suspension's scrub radius and steering geometry are so different that they have a different offset wheel. Indeed, the R uses only Pegasus. The non-R versions use only non-Pegasus. <p>Does anyone have an opinion on whether the 3 mm offset shift in S60 wheel represents a scrub radius shift, or a major steering geometry shift? (maybe I should post on the R forum).<p><br>
Discussion Starter #10
Re: (ukmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ukmatt</b> »</i></TD></TR><TR><TD CLASS="quote"><br>How can that be? a 225 tire is 8.86 inches wide and an 8 inch wheel is, um, 8 inches... <p>UKMatt</TD></TR></TABLE><p>I see your point! I have a feeling the so-called "Tire /w Wheel Inboard inrease" on that website is a misnomer, and it really simply means the inboard addition of the tire width. UKMatt is right. Naturally, going from 205 mm to 225 mm means 10 mm wider tire per side. Changing from 7 to 8 inches means 12.7 mm wider per side on the wheel, but really it's the tire width I would think that causes fitment problems. Come to think of it, people talk about fitment based on wheel width and offset change. Seems like they should really talk about fitment based on tire width and offset change.<p>
Discussion Starter #11
Re: (tmtalpey)
Informational:<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>tmtalpey</b> »</i></TD></TR><TR><TD CLASS="quote"><p>On the subject of rim vs tire widths, have found that TireRack's recommended sizes are spot-on. Their "acceptable" (or whatever second-tier rank) all look funny, either pinched or fat. I personally avoid them, which is what I think TR is trying to tell us.<p>Tom.</TD></TR></TABLE><p><br>I take your point. Here is some very interesting stuff from tirerack.com.<p><A HREF="http://www.tirerack.com/tires/tiretech/tirespecskey.jsp#measrimwidth" TARGET="_blank">http://www.tirerack.com/tires/...width</A><br>(check out the entire page)<p>Here's an example in action: the specs of a good tire.<br><A HREF="http://www.tirerack.com/tires/Spec.jsp?make=Goodyear&model=Eagle+F1+GS-D3" TARGET="_blank">http://www.tirerack.com/tires/...GS-D3</A><p>Seems like 7.5 or 8 inch width is okay for 225/45/17, most likely.<br>
Re: (bassman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>bassman</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Since Thor is 49 mm, I'm guessing Orestes and Orpheus are all 49 mm offset.<p></TD></TR></TABLE><p>Your guess is correct - 49mm on both.<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>bassman</b> »</i></TD></TR><TR><TD CLASS="quote">The S60R has 46 mm Pegasus wheel. So either they do recommend a 3 mm offset shift, or else the S60 suspension's scrub radius and steering geometry are so different that they have a different offset wheel. Indeed, the R uses only Pegasus. The non-R versions use only non-Pegasus. <p>Does anyone have an opinion on whether the 3 mm offset shift in S60 wheel represents a scrub radius shift, or a major steering geometry shift? (maybe I should post on the R forum).<br></TD></TR></TABLE><p>I have no idea... I was going to say that perhaps the 4C suspension in the R makes a difference but you can get 4C as an option on the S60 T5 and it still comes with the Orpheus wheels...<p>UKMatt
Re: (bassman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>bassman</b> »</i></TD></TR><TR><TD CLASS="quote">Does anyone have an opinion on whether the 3 mm offset shift in S60 wheel represents a scrub radius shift, or a major steering geometry shift? (maybe I should post on the R forum).</TD></TR></TABLE><p>I think it's the former - scrub radius. By reducing the offset, the (negative) scrub radius is also reduced. This benefits the R by reducing torque steer, which is larger in this higher-HP model. The difference from "stock" is quite small so overall it's just a tweak.<p>Tom.
Re: (tmtalpey)
I've got an idea how to measure the scrub.<p>- Find a flat smooth spot and lightly sand a small area.<br>- Park a front wheel on it with the steering dead straight.<br>- Turn the steering a slight amount each direction (so the wheel turns maybe +-10 degrees)<br>- Roll the wheel gently off the sand (or even jack the car)<p>If the scrub were zero, for a small arc the wheel will turn in a perfect circle close to the contact patch and you'll see a concentric pattern that "closes" all the way around.<p>If the scrub is positive, you'll see an "open" circle, the center portion would be somewhat empty. The open part of the C will point <B>inward</B>, and (I think) the radius <U>traced by the center patch</U> will equal the scrub.<p>If the scrub is negative, the same thing will happen but the open part of the C will point <B>outward</B>.<p>What do you think? If sand doesn't work I guess you could try inking the tire, or something like that.<p>Let us know if you try it! Well, let me know anyway. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> I might try it myself on the snow we're supposed to get this weekend.<p>Tom.
Discussion Starter #15
Re: (tmtalpey)
This might be ridiculous:<p>Does anyone have an opinion about 3 extra pounds on the wheel?<p>Sculptor and other normal V50 wheels are 22 pounds from what I know. Pegasus is 25. Other S60 wheels (Thor) are 22 pounds. Pegasus has some advantages, but weight is not one. Does anyone have a feel for how much 3 pounds extra unsprung weight in a rotational mass might have? I guess Volution and other wheels are even more...
1 - 15 of 15 Posts
