1 - 2 of 2 Posts
Is it possible to eliminate the stock PCV system and replace all the lines with AN hose or similar? Using an oil catch can and all AN hose would be much cheaper then replacing all the stock pcv pipes ($365) and such. I noticed the main PCV line has a banjo fitting on it and such, How could AN hosing be used to replace all the OEM PCV lines, if at all possible.
1 - 2 of 2 Posts
