Hi all.
I just bought a '98 V70 non turbo in desperate need of correcting years of neglect from the previous owner.
The car exhibits all of the symptoms of a clogged PCV system - white smoke from the dipstick tube, vague smell of exhaust in the cabin, black wet soot from the exhaust pipe on startup. I pulled apart the flame trap housing that sits near the throttle body in the intake tract, and the trap was perfectly clean and clear.
With these symptoms and a perfectly clean flame trap, would this make you believe it was more likely or less likely that the PCV box and tubes on the block are clogged?
Trying to get a better idea before I order a replacement kit and devote 8-9 hours to taking things apart (I'm just mechanically astute enough to make a hash out of things under the hood
Thanks in advance
Thanks in advance
