So the first problem has popped up on my Laser Blue V70R. Yesterday as I was driving, the passenger window stopped dead in the middle. The switch pack on the passenger door is no longer lit up. The master pack on the driver's door is relatively new and that wouldn't put the passenger window up or down either. Do you think I am looking at a dead regulator, a new switch pack for the passenger side, or something as simple as a fuse? Advice appreciated! Thank you!
Don't know the V70, but my V50 has a connector plug between the door and body. It has been known to get corrosion.
A quick test, and also protection from the rain, will be to pop the door panel off and use a battery to just run the window up by directly powering the motor. If that works, leave it unplugged until you figure out where else the problem lies.
No need to pull the door panel. Just pop out the window switch
in the passenger door and the motor leads are right there.
Unplug the switch and the two wires to the motor are:
Pin 1 - White
Pin 2 - Green
Good to know, thanks!
