1 - 1 of 1 Posts
Discussion Starter #1 (Edited)
This is for the cold air intake, not the movie... ;)
So, I ordered and already installed the IPD one on the drivers side, and I've seen a couple of threads that show pics of the passenger side one, but I don't think I've seen a thread with an actual install or parts list [since no one sells a dedicated pass. side kit yet].
I'd like to do one myself and source the parts etc. However, some of the things required you just can't search for, e.g. "fog light cold air intake funnel"
I use amazon links just for representation of parts. Some of these may be available at Walmart, Home Depot, or other places. If anyone has links for better prices or knows stores that carry these parts, please let us know.
RKelly, other folks who've done this mod, any input/help would be appreciated, especially with routing, placement.
Parts:
funnel: http://www.amazon.com/Allstar-Perfo...UTF8&coliid=I1CIAR0AZ4MQ6B&colid=67T1IATMB9RA
These are cheaper on ebay by about $10 when you factor in shipping. Would these work, or is there a better funnel to use? I've heard the offset ones aren't ideal for the passenger side. Btw, this funnel would definitely need to be trimmed a bit to fit in the foglight grill area.
If you use the above funnel, you'll need this: http://www.amazon.com/Jet-JW1020-3-...UTF8&coliid=I3UQ5NYIP29YF9&colid=67T1IATMB9RA
Let's you use the 2inch hose below on a three inch funnel
hose: http://www.amazon.com/Woodstock-W20...=UTF8&coliid=ICX4MZZOYUFFO&colid=67T1IATMB9RA
This one is clear [kind of cool].
clamp: http://www.amazon.com/Ideal-Series-...SY/ref=sr_1_16?ie=UTF8&qid=1331955565&sr=8-16
Buy this somewhere else for much much less. You only need one of these for the funnel to hose connection. No flange is needed to get the hose into the airbox, hence, no second clamp needed. Just wedge the hose through a 2inch hole in the airbox and save yourself some money.
Tools:
Flathead screwdriver
2 inch holesaw [easy way] or dremel and lots of patience...
Utility knife
Pliers w/ wirecutters
Silicone sealant [optional]
This is a cheap and effective mod for anyone who wants to get a little extra oomph at speed. With just the driver's side one installed, I can say the car really likes going 80+mph. Passing on the highway is effortless, as it just rams the air through the filter at 45+mph.
1 - 1 of 1 Posts
