1 - 13 of 13 Posts
If you have a part number and pricing for a S60R or V70R part please post it. No commentary in this thread.<p>Thank you.<p>ps: leave your sig off too to keep the thread short
Re: Parts Reference List (JimLill)
30676413 Cabin Air/Pollen Filter for IAQS-Equipped Car ($31)<p><U>Brake Venting/Ducting:</U><br>9190497-9 Air Guide (Left) ($17)<br>9190498-7 Air Guide (Right) ($17)<br>979878-6 Rivet (Need 8) ($2 total)<br>960138-6 Washer (Need 2) ($1 total)<br>979188-0 Six Point Socket (Need 2) ($1 total)<br>9484055-0 (Sealing Strip) (Need 2) ($26.22 total)
Re: Parts Reference List (bb vign)
<b>Body side molding</b><br>2005 L/F Fender 39987377 $30.60<br>2005 R/F Fender 39987391 $30.60<br>2005 L/F Door 39987405 $73.78<br>2005 R/F Door 39987419 $73.78<br>2005 L/R Door 39987447 $40.75<br>2005 R/R Door 39987461 $40.75<br>2005 Left front bumper curve 39994625 $21.02<br>2005 Right front bumper curve 39994632 $21.02<br>2004 Rear Bumper Trim 9484007 $80.81<p><b>MY05 Flat Blade Wipers</b><br>2005 Wiper Arm (Drivers) 30697573 $35.14<br>2005 Wiper Arm (Passenger) 30655615 $35.14<br>2005 Wiper Blade Kit 30663932 $32.81<p><b>Carpet</b><br>Carpet, Left - Grey 39988879 $167.78<br>Carpet, Right - Grey 39988882 $167.78<br>Carpet, Rear - Grey 39977614 $223.12<p><b>Accessories</b><br>Waste bag/Water Bottle Holder - Grey 30643165 $14.18<br>Volvo S60 Cargo area 12V outlet kit 9499090 $20.36<p><b>Tilt Sensor Alarm</b><br>Alarm Switch 9168279 $21.38<br>Level Sensor Kit 9499757 $80.81<p>Euro Fog Light Covers 30678050<br> 30678049
8698367 V70, S60 (00 >) Sunglass holder Light Grey (replaces o'head grab handle) ~USD$40<p>8670114 Electrical - Powertrain control - Mass air flow sensor, S60, w/Turbo, w/R Model 2004 - 2005 USD$199.24<p>8642206 Auto Gear Shift Knob w/R Model USD$131.07<p>30622083 Electrical - Powertrain control - Map sensor<br>MAP SENSOR, S60, w/Turbo, w/R Model 2004 - 2005 (IAT/Boost combi sensor) USD$86.20<p>8691888 Instrument panel - Cluster and switches - Trim cover - 7 switches 2004 - 2005 USD$6.04<p>1161745 Volvo Manual Transmission Oil, 3 litres ~USD$54<p>0977751 Volvo Oil Sump Gasket ~USD$0.88<p>1275810 Volvo Oil Filter ~USD$7.20<p>30649800 Volvo High pressure washer pump S60/S80 ~USD$59<p>30649801 Volvo High pressure washer pump seal ~USD$6.77<p>8636105 Clutch Hydraulic system Slave cylinder w/R Model USD$88.80
Thanks to my friend Michael who managed to speak to some Bosch people. They have listings for various car models and the equivalent Bosch replacement parts. Here are the R parts:<p><IMG SRC="http://i5.photobucket.com/albums/y197/KaminariAndachi/Bosch_List0036-1.jpg" BORDER="0"><p><IMG SRC="http://i5.photobucket.com/albums/y197/KaminariAndachi/Bosch_List0036-2.jpg" BORDER="0"><p><IMG SRC="http://i5.photobucket.com/albums/y197/KaminariAndachi/Bosch_List0036-3.jpg" BORDER="0"><p>Not listed in the list above is the alternative replacement part for our IAT/MAP hybrid sensor shown below:<p><IMG SRC="http://i5.photobucket.com/albums/y197/KaminariAndachi/boschsensoren-34.jpg" BORDER="0"><p>our OEM sensor is not listed there (0 261 230 106), but the equivalent part no. is (0 261 230 042).<p>For the above part no., the pressure range of our OEM sensor is the same, i.e. press range is between 20 to 250kPa (absolute pressure). What this means is that our OEM boost pressure sensor can only measure boost up to 1.5bar or 21.8psi (minus 1 bar for atm press). Beyond that boost level, the ECM will try to calculate the boost pressure...using other sensor inputs.<p>I have been using another bosch part no. 0 281 002 437 without problems for almost a year now in my 04R.... its plug and play... no codes thrown. This sensor measures boost up to 2.0bar (20 to 300kpa). As a side effect, the ECM still thinks that the boost sensor max value is at 1.5bar, so, it detects a slow build up of boost when I'm using this sensor. The ecu then tries to compensate by trying to build boost faster. NOT RECOMMENDED if you don't have compensatory devices to prevent boost spikes.... but it works well for me.
MAF Filter Security Bit (5 point)
5 Lobe MAF Bit - Part MN505000 $9.00<p>from: <A HREF="http://www.metalnerd.com/cat05.htm" TARGET="_blank">http://www.metalnerd.com/cat05.htm</A><p><BR><BR>
<i>Modified by duchski at 2:41 PM 6-28-2007</i>
Re: Parts Reference List - NGK Spark Plugs -- CORRECTION
NGK (non-EOM) replacement Double Platinum 7654 PLFR6A-11 $11.71 <p>Double Platinum plug, 14mm, 26.5mm (1.04") reach, 5/8" hex, gasket seat, resistor, projected tip, extreme long life double platinum, fine point platinum on center electrode, platinum tip laser welded on ground electrode, .044"gap<p>NGK extreme life plug. By using the highest platinum content in the industry, NGK has created an extremely long life spark plug. Laser welded platinum tip on center electrode and platinum tip on the ground electrode. The center electrode is taper cut which aids in focusing the spark while reducing the voltage necessary to start the combustion process, this will provide better throttle response, improve efficiency and allow a smoother idle. <br> <br><A HREF="http://www.ngk.com/more_info.asp?AAIA=&pid=3626" TARGET="_blank">http://www.ngk.com/more_info.asp?AAIA=&pid=3626</A><BR><BR>
<i>Modified by duchski at 1:33 PM 7-2-2007</i>
Banned
Re: Parts Reference List - spark plugs (duchski)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>duchski</b> »</i></TD></TR><TR><TD CLASS="quote">NGK (non-EOM) replacement:<p>Double Platinum Plug PFR6G (retail part# 4793) Gap .032 $12.00 ( x 5)<p>Plug is much shorter than OEM but still recommended by NGK for the R engine. Double platinum has extended longevity and ability to hold the specs; gap etc.<p>Works just fine in my '04.<br></TD></TR></TABLE><p>Just a note of caution about using the shorter plug from the T5 model. <p>First, since the reach is about 1/4 shorter than the R specific plug, the threads of the splark plug don't go all the way into the spark plug hole in the cyclinder head leaving a significant portion of the threads exposed to the combustion process. The exposed threads will become contaminated with carbon and when an attempt to install the correct plug is made, you could run into difficulty and or possibly damage tothe threads. <p>Second, the heat range of the plug is determined by the spark plug insulator length that is exposed to combustion process. When the in****or is recessed up into the plug hole, this will effect this process ( reducing thermal conductivity) . More importanlty the spark plug is also designed to draw heat from the combustion event. This is called the "Thermal Performance" or more commonly "heat range". In this case where the plug is not able to properly conduct heat away for the combustion chamber and into the cooling system, it could exacerbate an already weak area on the R. ( detonation under high ambinet loading) <p>Not sure how severe this could be in the case of the R, but I would advise against it as the correct plugs are readily avaialble and not much more.
<B>Part numbers ordered to fix ps groan:</B><p>The sound associated with low power steering fluid. The car makes this groaning sound when you make sharp turns with little or no power steering fluid. I had this problem on my last car, and it usually is from the lower hose from the reservoir leaking. Change the hose and clamp or keep an eye on it because these cars are prone to this problem.<p>Fluid Reservoir - 30645621<br>Suction Hose - 30740267<p><B>GT Transmission cooler-</B><br>Cooler, P/N 3063 6905, x 1<br>Inlet hose, P/N 3063 6906, x 1<br>Return hose, P/N 3063 6907, x 1<br>Mounting lower, P/N 3063 6908, x 1<br>Mounting upper, P/N 3068 0112, x 1<br>Screw M6x10, P/N 969 419, x 1<br>Screw M6x12, P/N 979 615, x 2<br>Screw M14x100, P/N 981 062, x 1<br>Screw M6x20, P/N 980 960, x 1<br>Screw M8x25, P/N 981 024, x 1<br>Washer 6.4x18x2, P/N 960 139, x 2<br>Cover left-hand side, P/N 3067 8050 x 1<br>Cover right-hand side, P/N 3067 8049 x 1 <BR><BR>
<i>Modified by vsigma at 11:27 PM 7-8-2007</i>
Re: (duchski)
vsigma said:
<B>Part numbers ordered to fix ps groan:</B><br>Fluid Reservoir - 30645621<br>Suction Hose - 30740267<p>What is "ps groan"?</TD></TR></TABLE><p>The sound associated with low power steering fluid. The car makes this groaning sound when you make sharp turns with little or no power steering fluid. I had this problem on my last car, and it usually is from the lower hose from the reservoir leaking. Change the hose and clamp or keep an eye on it because these cars are prone to this problem.
Since we're on parts, here's some software numbers:<p>FUNCTION FOR CAR CONFIRMATION / ADD¹<p>S80 = 9499 397-9<br>S60, S60 R = 8645 450-1<br>V70 00-, V70 R, XC70 01- = 9452 947-6<p>FUNCTION FOR CAR CONFIRMATION / REMOVE¹<p>S80 = 9499 398-7<br>S60, S60 R = 8645 451-9<br>V70 00-, V70 R, XC70 01- = 9452 948-4<p>Allows you to add or remove the visual confirmation signal to your car. This function makes the car's direction indicators flash once on locking if all doors are closed, and twice on unlocking.<p><br>Added the euro spec software that allows the fog lights to stay on with high beams. <p>P/N for S60R: 8619398<br>P/N for V70R: 9499585-9<br>
R Engine Code: B5254T4<p>OEM Spark Plugs: 30650379<br>(For engines: B5204T5, B5244T4, B5244T5, <B>B5254T4</B>, B5254T3)
1 - 13 of 13 Posts
