painted the FRP gauge pod but I can see some SMALL/MINOR scratches in the primer through the color coat. what grits of sandpaper will even these out? and what methods are recommended? <p>The highest I went was 320 in between coats and It seems like I just gouged a small area with the lower grit paper.<p>any help appreciated...I was trying to get in touch with my painter friend but hes MIA.
Re: Paint help... (mpdbrown)
Should have used 1500 grit
Re: Paint help... (JRL)
Thanks im going to go up in grit to 1500. Do you think the 1500 would be enough to smooth out the little scratches? or should I step it up gradually?
I have painted my vent gauge pod and had to do it with 2000 wet sand. Make sure it dries well before painting or the paint will crack<br>
Re: Paint help... (s140s)
cool.<p>just talked to my paint buddy he said 600 wet will even out the scratches and then 1200 wet should leave it good enough.<p>2000? how did it come out?
