I had the annoying "P1 Seeking...press Exit to Cancel" problem on my radio fixed (according to tech note TNN39-37 <A HREF="http://www.alldata.com/tsb/Volvo/1115362800000_1118818800000_TNN39-37/" TARGET="_blank">http://www.alldata.com/tsb/Vol...9-37/</A>). However, now when the rear park assist is engaged, the radio volume does not go down, as is it supposed to. <p>Anyone else with similar experiences?
Re: "P1 Seeking...press Exit to Cancel" fixed but rear park assist muting lost (chicagoxc90)
We did not have any issue with the rear park assist after the upgrade.<p>I would contact your svc center.
The mute option changed between the 2003 and 2006, maybe you notice the difference.<p>The mute only works now if the volume is greater than 50% unlike before
Re: "P1 Seeking...press Exit to Cancel" fixed but rear park assist muting lost (obiwan)
Obiwan,<p>You are absolutely right! The muting does work then the volume is >50%, but not otherwise as it did before. <p>I guess this "feature" was part of the software upgrade for the "P1 Seeking...press Exit to Cancel" problem. Not sure if this can be changed, but I'll contact the service rep.
