1 - 1 of 1 Posts
My 2003 S40 would occasionally go into limp mode, show the flashing arrow, and throw P0705 check engine light code. I had a local independent mechanic replace the PNP switch. He told me after he replaced the switch, CEL would turn back on immediately. He tried adjusting the alignment of PNP switch a dozen times, to no avail.
CEL remains on, but the car drives fine -- no more limp mode or flashing arrow. I took it to another indy garage and they said DTC code 76 is on, and said there must be some problem inside the TCM, so I should take into the dealer.
The dealer wants $150/hr for diagnosis, which I'm not ready to pay yet.
My cruise control works only intermittently. Could it be a bad brake pedal sensor that's causing the CEL & DTC 76?
Thank you for any ideas.
1 - 1 of 1 Posts
