So I was about to replace the purge valve in an attempt to get rid of this problem. When I found the valve I noticed that the filter in the picture became disconnected to a hose down below.
Could this be the reason I was getting the P0455 code?
Thank you gentlemen.
Absolutely
At the same time replace any of those hoses up there you can reach.
They look original and starting to crack.
If that doesn't work... smoke the car (vacuum system) to find the leak, that takes 10 minutes and can save HOURS of looking
I also doused the purge value in carb cleaner and it got rid of my code on my old s70 for about a year and a half now
