So... I did a bit of research on the P0171 code on the forum but didn't see any mention of the whining/high suction. Any thoughts on what it could be and where to look first? I don't have any fancy smoke testing equipment.
That's good, the hose isn't likely to affect anything, but always good to have the hoses in good condition as well.I replaced the oil trap. Whining noise is gone. Yay. Noticed that the hose connected to the oil trap had a small crack in a spot where it shouldn’t effect the seal to the oil trap, but I will replace this hose too.
I still have the P0171 code (reset it using Obd scanner tool).
think it could be the hose? Should I move on to replacing MAF? Or O2 sensors (not super cheap).
