1 - 2 of 2 Posts
2006 S60 2.5T AWD
Hi all, on the day my IPD catback arrives of course I get my first check engine on the s60, did some readings and got the P0026 & P0027 codes. I know it has to do with the VVT but still a little unclear. Anybody else get these? And if so what was the fix and how much $ did it set you back? Thanks.
Do you know if your PCV is needed to be done? These codes could be 2 things. The first one is that your PCV is needed, and you you got buildup inside the solenoid, and you need to clean it out. If this isn't what it is, then you will need a new solenoid.
IF IT IS THE SOLENOID, MAKE SURE THAT YOU REPLACE THE VVT SOLENOID GASKET!
1 - 2 of 2 Posts
