My son's 95 850 GLT was missing the switch and harness for the onboard computer. I got the parts and hooked them up yesterday. The ouside temp now displays LO. All other computer functions seem to be fine. What does the ouside temp sensor look like. I found a harness clipped to the under carriage behind where the fog lite shud mount on the driver's side. It just has a plastic cover over the the 2 holes I guess where a probe shud go. <br>If in fact there shud be a probe plugged in there where might be a good place to find a one?
If it's not in the front air dam like you suspect, look under the passenger side cowling to see if there's a clip and a sensor right where the air enters the cabin (also where you can add a cabin air filter). On the '95 they were placed in different locations. If in the air dam, then I suspect it's probably part #1347010. You can call <A HREF="http://www.fcpgroton.com" TARGET="_blank">http://www.fcpgroton.com</A> to see what they say about this part number and to see if they have it in stock. Will be cheaper than from the dealer.
